Sharp AR-M276 photocopier needs the maintenance Required to be reset.Please show me the Program Instruction to reset
Cogz
  • 1326 Answers
SOURCE: Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
Posted on May 09, 2008
Cogz
  • 1326 Answers
SOURCE: Reset Code
Did you do a PM on the copier? Or do you just want it off the display? You need to get in to service mode with pressing "#" "Interrupt" "Clear" "Interrupt" then enter 24 "Start" then go to sub code 04 then press OK to clear count. To exit press "CA" Good Luck
Posted on May 15, 2008
  • 3 Answers
SOURCE: Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Posted on Dec 26, 2008
  • 120 Answers
SOURCE: how to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Posted on Jul 09, 2009
  • 41 Answers
SOURCE: ar 5631 showing maintenance required error
Press the :
( #/P ) key --> ( * ) key --> ( clear ) key --> ( * ) key
reset the maintenance counter: 24 start --> 4 start
Posted on Aug 09, 2012
My sharp photocopier AR-M276 is showing error code U7-00. so what is the cause and remedy to it
Hi
U7-00 is pc/modem trouble, would you know whether you have a network port on the side of the machine, and whether it is connected to the network?. If you have and it is not connected to the network, that is what the error is, it is expecting an connection of some description.
if you go into settings on the machine, you can switch off the nic/tcp option, which should get rid of the error code.
Cheers
Andy
May 27, 2015 | Sharp Office Equipment & Supplies
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
My Sharp AR-M276 is printing but all the pages are coming out black. What should I do?
Get the software program and/or driver at the device website make sure your computer is up to date and check you'r color or trycolor make sure it is not empty...
Feb 09, 2015 | Sharp Office Equipment & Supplies
How can i fix error L4-01 for Sharp AR-M276?
hi you should chek drive system and fusing. dv cartridge. drum unit rotations ...... if there's was normal change main motor.
Sep 29, 2014 | Sharp Office Equipment & Supplies
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M276 m affiche maintenance requise code:U2-40,rien ne marche.je rallumer à plusieurs reprise ça ne marche pas.que faire?
it is IC conector problem.pull out the cartridge and put it into the copier again.if the problem still exists change toner cartridge.
Aug 15, 2010 | Sharp AR-5316 Advanced Digital Imager...
I got H4-00 problem in my AR -M276 Photocopy
Press # * C *, then enter 14 and press start, then 1 and start, then clear.
Jul 27, 2010 | Sharp AR-168S Copier
How to reset u2-40 for sharp AR266 photocopier
Hello sir; I'm not recognize this model number please double check,but I give you closer one to reset;
1, press "program", "interupt", "clear", "interupt".
2, enter 16 press start.
3, turn machine off and back on .
Jun 02, 2009 | Sharp AR-M205 Copier
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
jasbo
jasbo
