Please help it's a JVC TV Model Number LT-46P510 Serial Number 135G1483 I have called and asked different stores but to no avail I could not be directed to some one that could help.
To know more, you have to download the repair manual to this set. Its disassemble section will have all the details. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
SOURCE: MOUNTING MY TV ON A ENTERTAINMENT STAND
there is no problem i use the same bolts and it is ok from 2 years ago but for your paceful you can replace with other bolts approx 20 MM long
SOURCE: Need to set parental control pin
This TV calls it "V-Chip". Code is "0000" by default.
1. go to TV User Menu
2. select "TV" menu
3. selct "V-Chip"
4. change this to a lower setting
SOURCE: I have a 2006 JVC LT -32x585 Can it be wall mounted?
hi, this info will only be available in your owners manual or from jvc, do a google for jvc cust. service that should get you what you need, gl, video-tek
SOURCE: hi I have a JVC 32 D200 with the DVD on the side,
It is metric screw: 4mm thread and approximately 20mm long with a washer
Testimonial: "awesome thanks!!!"
SOURCE: I own a LT 42E488
This tv problems are 90% to 95% is it a dying power supply board.Power LED light indicator blinks or tv take a really long time to come on.The tv problems indication are the power supply board have dying capacitors parts,it usally or alway bulges up or puffing up onto it tops and leaking,not giving the tv power supply voltages correctly anymore to the rest of the tv other boards.The tv power supply board,that the board,where the power a/c cord plug into it.The tv shop,will charges u like 600-700 bucks,they'll repair the board or they'll put in another refurbish power supply board for the tv.U have some basic mechanical skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board to do the replacement ur self.The cost of power supply board like $100-150 bucks plus shipping the part to u.The take out and the reinstallation of the power supply board it pretty easy and straight forward,if u willing to take a chance and putting in some labors.
