Vizio e420vse doesn't power on when plugged in. Is this a power supply issue, a main board issue or LED driver issue?
When I power the tv on while it's plugged in, the front indicator light blinks but nothing else turns on. I was wondering if anyone had this issue and what the fix would be for it?
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Posted on Nov 13, 2014
SOURCE: Vizio P42HDTV Power on Diagnosis
Please check the U29 8 pin little surface mount mosfet it has this letters > FDS4935 > > In this part inputs 13.2 volts which is ok for the near 12 vdc but it > outputs 1.250 vdc i am 100% sure that this is all the problem > > check it out, and tell me if you´re agree with me > > On this output pin it feeds the audio Ic, the 7809 and the tuner side board > which needs de 12vdc too and its getting only the 5vdc part > > what do ya think?? > > Richard
Posted on Apr 13, 2008
  • 138 Answers
SOURCE: philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Posted on Aug 19, 2008
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
  • 2336 Answers
SOURCE: Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
Posted on Jun 08, 2009
  • 8457 Answers
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Posted on Jun 22, 2010
I have a Vizio E50-C1 Model #LTCWSKAR Power supply # (X)ADTVE2420AD4 Main Board #GXFCB02K009050X
You need to find out which board the led driver resides on. The main board sends a signal to the power supply board to turn on the LED's Look on the power supply board for swollen capacitors. They all have to have flat tops. If any are bulged, they have to be replaced www.shopjimmy.com. TV Parts Universal TV Stands DLP Chips ShopJimmy These guys can tell you which board you need.
Jul 28, 2017 | Vizio Televison & Video
Vizio 55" E55-C2 LED backlight issues. Was working fine until one day half of the screen's backlight stopped working and so half of the TV shows good and the other half is darker. Tcon or LED driver?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 13, 2016 | Vizio Televison & Video
To fix no video Vizio E470i-A0 TV
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 21, 2015 | Vizio Televison & Video
Vizio tv model e420vse turns on and then screen goes black. Still has power and sound. If I turn off and back on, the picture will come back for a few seconds and then shut off again. Vizio suggested it...
There are a lot of references on how to repair the LED backlight. If you can source the parts, google search LED backlight repair.
You may wish to read this first: http://www.techlicious.com/blog/un-repairable-vizio-tvs-leave-customers-out-of-luck/
Mar 31, 2015 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
Do you have vizio E420vse schematic?
sounds If the set gone into stand by mode. You could try switching it from standby mode. that's if you haven't damaged board.
check power to board while pressing standby.
Jan 20, 2015 | Vizio 42 in. LCD TV
Is there a way to fix a vizio e420vse that doesn't power on?
Most have a fuse in side other than that off to the repair man, get a quote as it could cost a lot.
Nov 13, 2014 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
How to fix tv turn off by itself
If the TV turns off by itself during working, there must be some fault with its main power regulator board inside. Check it. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 07, 2013 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
Vizio e420vse
If your TV is under warranty you have to contact the store where you brought it..
Jan 17, 2013 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
My vizio e420vse wont turn on
Did you check the fuse? Do you have 5volt standby power?
Dec 18, 2012 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
