Question about Rowenta DW9080 Steamium 1800-Watt Steam Iron w/ 400-Hole Platinum Soleplate
Rowenta DW9080 Auto/Off stuck. How do I bypass the Auto/Off feature, or find a replacement switch?
Rowenta DW9080 How do I bypass the Auto/Off feature, or find a replacement switch? I'm well aware of it's function, problem is auto/off indicator will not turn off so it will not heat. Yes I tried shaking it. I have emailed Rowenta customer service but they offer no help outside of sending it in for service($80+), won't advise part # for switch. Right now it's useless so any option would help. Ideally a copy of the factory repair manual, a couple pics of someone bypassing it, or referral to a source for a replacement switch. Also, anyone who can actually identify the actual auto/off switch, as I'm not sure which one it is yet. Thank you!
    Master:
  • Rowenta Master
  • 996 Answers
Thermostat defective,,,can be do drect by expert professional,,,but it will burn your all clothes due to very hot position,without auto cut
Posted on Jan 21, 2015
  • 17 Answers
SOURCE: Doesn't heat up...
Authorized Appliance And Repair in St. Louis Mo, works on all model Rowenta Irons.
Posted on Nov 03, 2007
geokohler
  • 304 Answers
SOURCE: Repairing a Rowenta DX8800
It sounds to me like the thermal cutoff switch has blown. Irons have these as a safety device similar to a fuse to protect against fire in the event the iron gets too hot. These are not very costly to replace. Here is a link to where you can buy them:
http://www.welco.com.cn/?gclid=CJiWv7TN2ZQCFQpzHgodl1LXQQ
, Make sure you get one of the exact same cutoff point as the one designed for your Iron. If you put in a higher temp device it will be harder to blow but will make the iron dangerous as it may cause a fire if it over heats. Some shady repair men will just bypass this and the iron will work again fine but this is a dangerous practice as it directly puts you of danger. If you do have it repaired at a shop demand for the old thermal cutoff from your unit when you drop it off so the tech will know you know what is wrong with it and that you will check to make sure that it has really been changed. This will also not give him the chance to over charge you when he knows you know it is only a 1 dollar part and easy to change.
This device is very easy to change, If you can open your iron you could easily do this yourself. The part, as you will see on the site where you buy them, only has 2 wires one comming out of each end. You simply cut out the old 1 and replace it with the new one. You do not even have to worry which end goes where. It is like a fuse, it works the same either direction. You have to buy some wire crimp connector to connect it, you can not just solder it in due to the heat in the iron. In a pinch you could just securely twist the ends of the leads with the leads from the old cutoff if you clip the leads from the old cutoff real close to the device. This will leave you with plenty of wire to get a good twist. I always use the crimp connectors so it looks more professional.
Anyway, I hope you found this to be helpful and if you need more help feel free to ask me. I will stay with you on this until we have it fixed.
George
Posted on Jul 24, 2008
SOURCE: Rowenta iron manual needed
does not heat but indicator light is on.
Rowenta steam Iron Model DE-871
Posted on Dec 26, 2008
thydzik
  • 86 Answers
SOURCE: I have a Rowenta Pro. Iron, model DE-86.1A with
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Posted on Jul 22, 2009
  • 4 Answers
SOURCE: How to hardwire rowenta powerglide to bypass safety switch
lancell - you're an idiot...of course he understands - that is why he is asking!
Posted on Nov 25, 2009
I own a Rowenta Steamium DW9080 steam iron. I need a replacement plastic door for the water reservoir. The iron is functional and I do not feel it necessary to purchase the entire handle and cord...
Not familiar with that newer model, but here is the local dealer who is most helpful in California:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Aug 29, 2011 | Rowenta DG-980 Iron
How to clean
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
Aug 22, 2011 | Rowenta DW9080 Iron with Auto Shutoff
IRon heats standing but the light goes out when I set it horizontal to iron a garment. I think the cord is needing replacement but need advice.
If the iron is not moved while it is plugged
in, an internal safety switch will turn it off.
- It will turn off in 8 minutes if left vertically or
in 30 seconds if left on its soleplate or tipped
over. A red flashing light indicates that the
auto-off has been activated.
The above information is from the Rowenta DX1700 Owner's Manual. I think most, if not all Rowenta irons have the "auto off" safety feature. If your iron is going off before the 30 seconds idle time, the sensor may be defective. If you are letting it sit on the sole plate longer than 30 seconds, you may just need to work faster. ;-)
Jun 11, 2011 | Rowenta Irons
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Sep 24, 2009 | Rowenta Powerglide DE011 Iron with Auto...
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
Jul 22, 2009 | Rowenta Irons
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta DW9080 Steamium 1800-Watt Steam Iron w/ 400-Hole Platinum Soleplate Logo
995 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
