When I try to change my bio the bio option does not show up
    Top Expert:
  • Computers & ... Master
  • 26,637 Answers
Make an model would be useful but try ether Esc, F2 or F12 just before it tries to boot up.
Posted on Nov 13, 2014
How to change boot order dx4200-ub001a?
To change the boot order, you will want to go into your BIOS. From the HP.com website it shows the following below to enter the BIOS:
BIOS Setup Utility Information and Menu Options
  1. Turn off the computer and wait five seconds.
  2. Turn on the computer and immediately press the F10 key repeatedly until a BIOS Setup screen opens. If nothing happens, press the F1 key repeatedly.
Use the arrow keys to move through the options (Note the commands key list in the lower right of the link I provided to HP.com) You will likely need to enter the advanced area to change your boot order.
Aug 29, 2014 | HP Pavilion Computers & Internet
Sleep button won't activate
I'll assume you're referring to the Sleep option accessed through the shutdown menu in Windows. My bet is you'll have to make a change to your power plan in the Power Options section of the Control Panel. You should see a few pre-configured power management options like "Power Saver" and "High Performance." To the left of these options should be a sidebar containing more specific and direct links to changing how your computer behaves and what options are available.
If you cannot resolve your problem through using the Power Options under the Windows Control Panel, I suggest you enter your BIOS setup (you'll have to restart your PC), and press the right arrow key until you're on the last page of BIOS setup. Once there, press the down arrow key until the option to load "default settings" is highlighted, and then press enter. Then highlight the option to exit saving changes and press enter, allow the computer to boot normally into the Windows desktop, and check the sleep option again. You may have to select the default BIOS settings before making changes in the Control Panel, but I would recommend trying the Control Panel first.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Jun 01, 2014 | HP Pavilion Media Center m8530f...
Dell 4600
When editing the BIOS if you go into the BOOT ORDER menu, it is possible that the network card is not showing as an option. In order to get this option to display, go into the "integrated devices (legacyselect options)" and then select the network interface controller. Edit that even if it is On and change it to On w/PXE. After saving the changes to the BIOS, you need to power the computer off then on and then go into BIOS again, and the "integrated NIC" option should be available in the BOOT ORDER menu. Set this to be the first boot device in order to use PXE.
Apr 10, 2014 | Dell Dimension Computers & Internet
Thinkcentrre 8143 can't change bios
The f10 is usually the save and exit or exit options key. Your particular version of BIOS should tell you in one corner of the screen.
May 17, 2012 | IBM ThinkCentre® M51 (8143-WVS) PC Desktop
Tried to install win xp but windows cannot detect harddrive harddrive detected in bios
GOTO BIOS and change your hardisk LEGECY MODE
that is show in advance option
Hope this helppful
Jan 12, 2011 | Computers & Internet
USB not working under Windows
Try resetting BIOS and also check whether the Plug and Play service is activated.
May 28, 2010 | Intel Computers & Internet
Want to re-format MSI Notebook S420. Screen continuously shows windows 'loading' but never boots. I have the recovery CD but because the computer never actually starts, I'm not sure what to do with it!MSI
Hello megan_van
While your laptop is on, eject the optical drive and insert the recovery CD. Turn off your laptop via the power button, and turn it back on. The recovery CD should boot. Follow the on-screen instructions to do a clean install.
If the recovery CD doesn't boot, try holding down the C key after turning on your laptop. If it still doesn't boot, you will have to change the boot order in BIOS. Don't worry, this is easier than it sounds! Follow these instructions:
1. Turn on your laptop, and look for a message that says something like PRESS (USUALLY F2, F8, DEL, ETC.) TO ENTER SETUP / BIOS. Hit that key before the Windows logo appears.
2. After hitting the relevant key, you'll be taken to the BIOS setup utility. All BIOS utilities have different appearances, but it is basically a set of menus containing different settings for your laptops hardware. Somewhere on the screen (usually the bottom), is a set of instructions for navigation your way around the BIOS. Follow these instructions to navigate your way to the option for changing the boot order.
N.B. Since every BIOS setup utility is different, the specifics on where the boot order options are located varies from computer to computer. The menu option or configuration item might be called boot options, boot, boot order, etc. The boot order option may even be located in a general menu like advanced options, advanced BIOS features, other options, etc.
3. Once you've located it, use the navigational controls to place the optical drive above the hard drive (usually the +/- keys). To be certain that the recovery CD boots, it's probably best to move the optical drive to the top of this list.
4. Within the navigational controls, there is usually an option to SAVE & EXIT. Press this key. If there isn't, look for a menu option with the heading EXIT. A SETUP CONFIRMATION box will now usually appear asking you to confrm the changes you've made to the BIOS before exiting.
N.B. The SETUP CONFIRMATION box can sometimes be worded cryptically. Read the message carefully to be sure that you're saving your changes instead of exiting WITHOUT saving your changes!
Your computer should now restart automatically, and the recovery CD should now boot.
Hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | MSI MEGABOOK M510C Notebook
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
Bios settings changed automatically
Have you tried to update the bios? One of the latest versions BIOS Update [DPP3510J.86A] 07/15/09. But verify to ensure that you download the correct bios for your board. There are a few options available. Also check the jumper pins for the bios on the motherboard normal or (default) setting is pins 1-2 jumped.
Nov 10, 2009 | Computers & Internet
Changing shared memory
here.,. follow this thread..Dukesite shows the fix ..its bios update
http://forum.notebookreview.com/archive/index.php/t-92680.html
Jun 01, 2008 | Dell InspironTM 1501 Notebook
Computers & Internet Logo
David Payne
David Payne
