Question about Jenn-Air Refrigerators
How do i replace the water filter
Model# jcd2389ge
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
Http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2389GES/1266/0165000
Posted on Nov 13, 2014
Where is the water filter on my whirlpool model gx2fhdxvy09
Water Filtration System
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Do not use with water that is microbiologically unsafe or
of unknown quality without adequate disinfection before
or after the system. Systems certified for cyst reduction
may be used on disinfected waters that may contain
filterable cysts.
IMPORTANT: The disposable water filter should be replaced at
least every 6 months. If the water flow to the water dispenser or
ice maker decreases noticeably before 6 months have passed,
replace the water filter more often.
Replacing the Water Filter
To purchase replacement water filters, model UKF8001AXX-750
or model UKF8001AXX-200, contact your dealer or call
1-800-253-1301 U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. See "Water and Ice Dispenser(s)."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
User Manual=> HERE I am here should you need me, Thanks John Tripp Appliance 911
Apr 16, 2014 | Admiral 26 cu. ft. Side-By-Side...
Water does not flow
first you should take the water feed off, clear all water out of tube going to ice maker.remoe ice maker and check the wiring and all looks good.hook water up,turn water on just enough to see you have waterflow yo ice maker.might need a towel or two in the freezer.replace icemaker,make sure bar on ice maker is down,turn water on full,give it 12hrs to make ice. good water flow-no ice--replace ice maker.
Jun 02, 2012 | Jenn-Air JCD2389G Side by Side...
I have water leaking from the bottom. I turned off the water in the back and the problem stopped. Where is the water most likely coming from and how can I repair it? Model #JCD2389GE
Hello
Suspect your main water inlet valves .Usually ,they are behind kick panel bottom front of machine.Look for two small solonoid valves with tubing attached and inspect for leaks.Unplug machine to make repair,there is 120 volts down there.
Hope this helps
Sep 05, 2011 | Jenn-Air JCD2389G Side by Side...
Can't find where the filter is located on a JCD2389GE
Your water filter is located in the upper right corner of the refrig.compartment above the upper most shelf in the ceiling.
GENE
Aug 31, 2011 | Refrigerators
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
IS THERE A RECALL ON JENN-AIR REFRIGERATOR, MODEL #JCD2389GE ?
MAYBE!  Our Jenn-Air side by side has a similar model number to yours and it was recalled on March 10.  Check on maytag's recall page to see if your fridge has been recalled by entering your model and serial number.
Mar 11, 2009 | Jenn-Air JCD2389G Side by Side...
I have a JENN-AIR side-by-side refrigerator Model # JCD2389GE. The freezer side works great but the refrigerator side barley gets cold. Help!
the damper on the left corner in the refrigeartor is not opening is either blocked with ice or broken also when the frezeer is not defrosting like it supost to it blocks air circultion to fresh food section check both thing damper and defrost
Nov 09, 2008 | Refrigerators
JCD2389GE Fridge Lock Button Is Lit
Solution found! I located manual on line. If anyone else has this problem, press the "lock" button three times in ten seconds! I'm a genius!
Jan 27, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
87 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
