Question about Rheem Classic Series 95% Two-Stage Upflow 105k BTUH Gas Furnace with Dual Comfort Control
Is there any process needed to implement for the summer to winter thermostat settings
I have a rheem vertical furnace with the AC attached
    Problem Solver:
  • 8 Answers
You didn't mention what thermostat(s) you have but most simply require you to go from cool to heat and then check the temp setting(s0 to make sure they are in your comfort zone.
Posted on Nov 23, 2014
LUX TX500E thermostat flashing fan. Have installed batteries backwards and reset to factory settings installed new batteries as well. Still flashing fan. Furnace not working.
With this thermostat, it may be flashing FAN because the HVAC (any heating or cooling unit) unit isn't working. In the winter, the pilot light for the heat may not be lit or the air intake/exhaust could be blocked. In the summer, the AC coils could be frozen or there may be another problem. Go to the HVAC unit and look for any lights at or near the control board. Check the outside unit for problems as well.
If there is no problem with the HVAC, try resetting the software in the thermostat. Use a bent paperclip to press the reset button above the Next button; the reset button is inside a small recessed spot. If the problem persists, try a different thermostat. If a different thermostat doesn't work, the HVAC system needs to be serviced.
I hope this helps. Please add a comment with the type of furnace you have (electric, gas, oil). That might help determine what issue you need to look for on the main unit.
Jul 03, 2015 | Heating & Cooling
Where is the summer/winter switch located on Dayton Fuel Trimmer furnace model 3E438A.?
The typical 'summer/winter' switch is an added switch associated with OLD heating systems back in the 50's and 60's before central air conditioning became common in homes. I doubt that your new furnace had one installed because you can accomplish the same thing by switching the fan on at the thermostat sub-base. That is, of course, providing you have a subbase with 'fan-on-auto' on it.
Jan 07, 2015 | Dayton Heating & Cooling
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
I can't find the summer switch on my furnace model FG6RA 072C-12A
there isn't a summer switch - the thermostat will switch the operation from heat/winter operation to cool/summer operation. I.E. "Cool" for Summer and "Heat" for Winter.
Aug 05, 2011 | Heating & Cooling
Not blowing as much air out of the vents
Check your filter, could be dirty and restricting the airflow.
Also, most furnace/AC combination units are set to blow more air in summer and less in winter, could be you're used to summer airflow level.
Dec 16, 2010 | Heating & Cooling
20 year old Rheem 90 plus 120k btu furnace blower runs contantly. Furnace and AC work fine (start and stop according to thermostat setting). What is problem? How fix?
Check to see if your unit has a heat sequencer. This is usually the problem with most furnaces. If it is bad, it will make the fan blower run all of the time. If you are not a electrican, you may want to get a electricin to look at it.
Dec 01, 2010 | Heating & Cooling
We have a Weatherking Heater/AC unit the heater works and the AC worked last summer when we tried the furnace this winter no heat found out it was the 24 volt transformer replaced it and heat worked fine...
I think you have a definite short and it's in the 24 volt circuit. The only problem is - 'finding a low voltage short' is not the easiest thing in the world to do - so - I would guess you'd need a Service Tech.
good luck!
Jun 28, 2010 | Heating & Cooling
I have a Rheem Gas Furnace with an old analog thermostat (Wires conneected to terminals R and 4 for the thermostat). I went to install a Rheem digital and programmable thermostat and it indicated that it...
if you have 2 wire at thermostat Terminals at furnace that the thermostat wire attach to should be R & W if your new thermostat has R & W terminals is should work, an easy thing to remember is the red wire on R the white wire on W. If 4 wire at thermostat at furnace green on G, Blue on Y, red on R,and white on W same at thermostat If these do not match find a thermostat with these terminals
Dec 06, 2009 | Heating & Cooling
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Rheem Classic Series 95% Two-Stage Upflow 105k BTUH Gas Furnace with Dual Comfort Control Logo
63 people viewed this question
Top Rheem Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Rheem Garden Expert? Answer questions, earn points and help others
