Question about Refrigerators
I have a whirpool fridge model GB2FHDXWS09 how do I tighten the handles?
  • 721 Answers
There is a hex screw top and bottom of handle. Use an allen wrench, tighten screws till snug. GOOD LUCK FRIEND.
Posted on Nov 13, 2014
  • 54 Answers
There should be screws on the top and bottom of the doors.
2 Suggested Answers
  • 4 Answers
SOURCE: I have a migali fridge model#r28t. The handle is
either get some no more nails glue or some liquid metal and mix it up and follow the instructions on th pack...failing that you might be able to drill it and use pop rivets,you dont ned reare accessfor these.
Posted on Oct 13, 2010
Kenmore Side by side fridge/freezer Model; Jsi 23. How do you tighten handle? I see no removable screw hole covers and nothing visible behind seal inside door.
Try pushing in on door handle & pushing up simultaeneously. If handle comes off there may be srews holding the clips.
Apr 18, 2018 | Kenmore Refrigerators
Samsung French door fridge freezer handle came loose. The ***** on the right side fell into the back of the handle attachment so it won't go flush with the fridge.
Hello Marilyn;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on a label on the inside liner of your fresh food section.
Usually the door handles are held on in one of two ways.
1.) Inspect the sides of the door handles. Are there small allen wrench screws - tighten them.
2.) Ok, no screws on the side. There are mounting brackets screwed onto the door. At times the screws become loose. Use a little muscle and pull the handle up hard to release from the bracket. Tighten the screws on the bracket to the door. Position the handle back on the bracket and pull the handle down hard until secure.
Mar 03, 2016 | Samsung Refrigerators
We have a 3 month old fridge and the handle is coming away from the fridge. There is a bolt under the handle which suits a 4mm allen key, but it does not seem to do anything if you tighten or loosten it. ...
The bolt on the handle tightens on a pin that comes through the door. If the tightening the screw on the handle and it still does not tighten then the pin has come loose inside the door. If the unit is only 3 months old I suggest contacting who you bought it from. It should be under warranty.
Feb 03, 2015 | Refrigerators
How to tighten handle on frigidiare fridge
Hello friend, thanks for the post!
I understand you are seeking some assistance on how to tighten your door handles for your Frigidaire refrigerator that is listed under model FFHS2611LB. This is not a typical DIY job I would recommend you have a technician come out to the home to tighten the handles. -Matt
Jul 29, 2014 | Frigidaire FFHS2611LB Side By Side...
Door handle came loose .how do i tighten it up`
hello kyler.... Empty out the contents of the door of the fridge. Then pull up the gasket and under that you will see screws. Remove those screws and the entire inside of the door is released exposing the screws to tighten the handle. Joe
Thanks for choosing Fixya!
Feb 24, 2011 | Whirlpool Refrigerators
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Oct 29, 2007 | GE GSH22JFR Side by Side Refrigerator
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
