The water drainage point (a small black pipe) has been sheered off so that we can no longer attach the drainage hose. Is it possible to fix it?
    Genius:
  • 2,486 Answers
It may be possible to drill it out and glue a slightly smaller hose up in side it .
Posted on Nov 13, 2014
SOURCE: Whirlpool Air Con Drainage issue
Yes, there should be a place for the condensate to drain outside. It's apparently clogged and the drip pan is overfilling. Look for a tube or an opening outside where the condensate should be exiting. This needs to be unclogged.
Posted on May 31, 2009
co7196
  • 3433 Answers
SOURCE: Constant leaking water
The unit must be level and the hose lower than the machine. -Good Luck-Ned_
Posted on Aug 23, 2009
  • 29 Answers
SOURCE: My splict ac system is not draining the water
try lifting the unit off the wall and making sure its level and flat against the wall so the water flows as it should in the tray
common install related problem
cheers
Posted on Jul 05, 2010
caroldon
  • 17130 Answers
SOURCE: water is backing up and
The water dripping from evapourator is due to clogging of the cooling pins.where in the condensed water logs into the front portion into the filter,the front pannel and to the wall.If the unit is slightly tilted, this would be reduced.use a good brush and air pressure to clean the fins.If periodical cleaning of the filter is not done,this can happen.
Posted on Sep 02, 2010
  • 59 Answers
SOURCE: Free standing Convair Supercool leaks
The water is being generated from humidity inside the air. The air conditioner also acts as a dehumidifier. The black line is the drain. The drain line needs to go to an outside line or to a container to collect the condensated water. With low humidity levels, the water will evaporate back into the air. With high humidity, the water is removed from the air at a higher volume than can evaporate back into the air.
Posted on Jan 29, 2011
Fluidmaster instructions
Turn off water at valve. Drain tank. Remove fill line that goes to bottom of tank. Remove large nut from underneath tank holding in old fill/float valve assembly. Clean area around hole in tank above and below. Get large black washer from kit put onto bottom of fluid-master pipe (lip side down). Place fluid-master into hole from top of tank to check height. Top of fluid-master valve should be even or just a bit below top of tank. To adjust hold head of fluid-master and turn pipe ccw to lengthen, cw to shorten. Once adjusted put into tank. Using large flat nut in kit tighten to tank, making sure its centered in the hole, no part of the float touching the sides of the tank, and that the small nipple on the side where the small black hose will attach is facing towards the overflow pipe. Make it nice and tight, but don\'t break it.Then re attach water supply line you removed earlier, hand tight only. Place pipe clip onto top of overflow pipe (funny looking plastic clip with metal piece attached). Attach small black hose to fill valve nipple on side of valve, other side to funny clip. You may need to cut it shorter so it doesn\'t kink. Tun on water and adjust float if required. Level should be 1/2" below top of overflow pipe.
Aug 23, 2014 | Home
Toshiba washing machine model AW 9790s error code E1
E1 is the drainage hose error, check the drainage pipe hose is not blocked damaged or filled with water or frozen, or maybe the return sensor for the hose is switched sensing something is wrong with the pipe but isnt. check the drainage hose ensure all water is out of the hose. open and close the lid one, then press the start/hold button this should reset the error alarm.
I hope this was useful
Feb 15, 2013 | Washing Machines
Dishwasher Whirlpool quiet partner 2 will not drain
Check your drainage hose going to the kitchen sink. It should be routed up to an air gap on kitchen sink, or ran to the highest point as possible under the kitchen sink counter and then slope down into the disposer or branch wye tailpiece on your drainage piping depending on what your drainage configuration is. Not going up to the highest point, or an air gap, before draining into your drainage piping allows the water inside the dishwasher hose to drain back into the unit.
Feb 21, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Ok so I need to know how to stop the water coming out of the back of the AC I want to see how I can drain the water PLEASE HELP MEEEEEEEEEEE
ok the air con must release water as its condensation there should have been a small rectangular tray that came with the air con it attaches to the underneath left hand corner with a small bit of pipe that can connect to a peace of hose and run down the wall to a good drainage area
good luck
Jun 25, 2010 | Goldstar KG6000R Window Air Conditioner
Water coming from indoor unit
The problem is caused by fine particulants such as dust, pet dander, etc. which mix with the collected condinsation water and forms a grey gel eventually clogging up the drainage pipe. The solution is to attach a wet vaccuum hose to the discharge end of the drainage pipe and vaccuum out the gel. It is advisable to flush the system by adding water to the a/c's drain pan while the vaccuum is still running.
Oct 07, 2009 | Mitsubishi Heating & Cooling
4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Jul 26, 2009 | Bosch Dishwashers
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
Dishwasher
you can buy the drainage hose ( B&Q) by the per / m if you can not install a drainage pipe closer.
May 30, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Feb 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
