Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a coleman powermate 6250 generator and i am not getting any sparks to the spark plug can someone help me out with this problem
Its been sitting up for 6 months and it wont start i checked the plug and its fine ,theres no spark coming to the plug,the gas is fine ,the oil is fine what could it be
    Sergeant:
  • 417 Answers
The easiest way to do an ignition check is to MAKE SURE the right amount of oil is in the engine, make sure there's FRESH fuel in the tank, and then where the on/off (I/O) switch is for the engine, not for the generator half but for the engine itself, there should be atleast one if not a cluster of wires with disconnectable links on them. Disconnect them, those are all of your ignition wires from various areas of the engine and generator that will kill the ignition if something isn't right. If you disconnect the main one from the on off switch, there should now be a spark but be careful because with all of that disconnected, you won't be able to shut the machine down easily, you'll have to remember which wire goes where that you disconnected (good idea to photograph them before you disconnect more than one wire) and either reconnect them, choke out the engine which may not kill it either, or disconnect the coil to spark plug lead from the spark plug. An easy way to check for spark without disassembling anything first, is to get a long Philips screw driver with a plastic or wood handle, and stick it in the coil lead where it would go on the spark plug. Hold the handle and bring the shaft about 1/8" or less without touching it to the tip of the spark plug that's metal and exposed. Have someone pull over the recoil once and check for an arc going from the screwdriver shaft to the plug. Make sure the I/O switch is on and being in a dimly lit area helps to see the spark as well. Don't worry about getting zapped, it won't kill you an it doesn't hurt, just feels like a violent vibration isolated to the area you are touching and instinctively your body will release from it and you should pull your hand back. But, if you follow my instructions and use the correct handle material screwdriver and don't touch any metal, you won't be shocked, promise. Chances are, you DO have a spark and there is nothing wrong with either the coil or the plug as it rarely ever is in no-start situations. More than likely your fuel has gone bad and is not making it to the engine. You can even avoid all else I said, and simply pick up a can of carburetor cleaner NEVER STARTING FLUID, and once you have the air filter completely removed and can see the throttle plate, hold it open, spray a quick shot of the carb cleaner into the engine, and give it a yank. I almost guarantee it will try to fire on the carb cleaner and once it runs out, will die again. That means you aren't getting fuel and need a new carb. Yes, a new carb, because taking it to a place to have them remove it, rebuild it, and reinstall it while trying to sell you other services will be infinitely more expensive than a simple $50 carburetor.
Posted on Dec 03, 2014
    Genius:
  • Coleman Master
  • 2,669 Answers
You will have to remove the flywheel and check the ignition out there.
Posted on Nov 13, 2014
  • dennys23601 Nov 13, 2014
    no the fly wheel does not have to come off.
  • 251 Answers
SOURCE: Coleman Powermate 6250 generator - shut off
the usual reason is a stuck float in your carburator , can be caused by dirt/rust etc , remove carb bowl and clean , there is also a very small needle valve which is attached to this float ( metering needle ) these can leak.
if all else fails always turn off the fuel supply to the generator whilst not in use
Posted on Oct 21, 2009
CarlGehrke
  • 169 Answers
SOURCE: checking the gas and oil levels?
There isn't really a guage to look at . What one does is to take out the plastic plug on the side of the engine and with the engine cold and level make sure that the oil level comes up to the lowest thread where the plug screws in.
You really should have a manual, so if it's missing look here for which ever "PM" number is printed on the tag on the end of your generator.
Regards,
Carl
Posted on Jan 07, 2009
sal_kh_sab
  • 98 Answers
SOURCE: powermate 6250 wont start
try checking the WKM setting...i dont know what its called in english....but we call it WKM ...on my gen. its a peice of metal (with OHV written on it)...if you don't know how to set it...send me an email at
sal_kh_sab@yahoo.com
Posted on Oct 11, 2009
al_kupchella
  • 843 Answers
SOURCE: Coleman powermate with 10 hp Tecumseh. Never
There are a couple of switches on these things, and their positions and the little icons on them are NOT intuitive - well maybe they are intuitive to the under-20 crowd. I lent mine (which starts right up) to a friend who spent an hour or two pulling the cord before he noticed how to turn it on. I'm not trying to be a smart-alec. I hope this helps.
Posted on May 17, 2010
ROMOAS
  • 97 Answers
SOURCE: I have a Coleman Powermate
when the engine sets for a long time the gas can seep bast in to the cylinder and their will be some gas you will need to change the oil and take the spark plug out and air i suggest you squirt a small amount of oil in the cylinder gas in the cylinder can wash out the lube to the rings and cause undo wear and start smoking turn the engine by hand slowly to allow lubing of the rings the gas seepage is most likely caused by a float that's not set correctly you may need to rebuild the carb with a kit around 20 bucks ans easy to do at least the clean it well to remove schlack that gas leaves behind when it dissipates and can cause issues.
replace with fresh gas and run the engine and it will smoke for a couple mins do to the oil in the cylinder remove the spark pug after running a couple mins and clean or replace the engine should be fine following the steps above. hope this helps
Posted on Aug 31, 2010
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
A Coleman Powermate 6250 with a Briggs and Stratton engine new won't crack. Got gas to crab and motor full of oil. Spray starting fluid in it it until it's gone. Why wouldn't it start? ??
If its new, SOME generators will not start unless at least 3/4 full of gas. Spark plugs secured all the way in? Gas switch on? Pull the choke? NO MORE starting fluid, Bad Louie, BAD! some of the suggestions i posted above may help :) but, no more starting fluid.
Jun 29, 2016 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Robin engines won't start
Look for kill switch. Make sure it is wired correctly and not broken or something like wires no connected. It cuts spark when activated so likely the problem since its in-line with exciter.
Jan 04, 2014 | Coleman Powermate Premium Plus 6250...
How do you change the spark plug on a Coleman Powermate 5000 10P Generator? It has been sitting for about eight years since last use and won't start. Would like to change the spark plug, but it seems...
The plug is under the gas tank. They can be difficult to get to and you may have to remove/loosen the tank. If you can remove the spark plug wire you could test for spark. If you have a spark and it still doesn't crank the spark plug is probably the least of your worries unless you drained the tank and the carb (most people don't.)
If you have a spark give a spritz of starter fluid into the carb after removing the air filter and see if it runs for even a bit. If it does fire and doesn't run, clean the carb.
Good luck.
Jan 07, 2018 | Coleman Powermate Powermate 5000W...
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman powermate 6250 no spark, switch on, has oil. changed spark plug.
check wiring most likely loose wiring, happens when your generator viabrates
Nov 11, 2009 | Coleman Powermate Premium Plus 6250W...
Powermate 6250 wont start
Sep 05, 2009 | Coleman Powermate Premium Plus 6250W...
Hi im working on a coleman powermate/pulseplus 1750 generator, i can not seem to get any spark, i cleaned the magneto,and fly wheel and still no spark,and i had the magneto check,the guy said theres...
As silly as this is going to sound, make sure the oil level is right. I have a Powermate 6250 that did the same thing to me. Turned out the oil was just a little too low and the sensor was killing the power. When you try to start it, the red light will be flashing in the on/off switch, that's the low oil indicator. Hope this helps.
Aug 28, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
200 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
