Question about Apex Digital Televison & Video
I believe I gave you the wrong info, I don't have a flat panel APEX. It is the regular rounded screen. I don't know if this will change your answer, but I sure appreciate your help. (I was ask
I believe I gave you the wrong info, I don't have a flat panel APEX. It is the regular rounded screen. I don't know if this will change your answer, but I sure appreciate your help. (I was asking how to turn off closed captioning.)
    Top Expert:
  • Apex Digital Master
  • 75,320 Answers
What is the problem you faces with this TV? Provide more details, please. http://electronicshelponline.blogspot.com/
Posted on Nov 13, 2014
  • 87 Answers
SOURCE: closed caption
Solution #1posted on Jul 23, 2007 By QTV1 Rank: Guru Rating: 93.33%, 6 votes Press menu on the remote. Press the cursor up or down button untill the word CC is highlighted. Press the cursor right button to select Closed Caption 1. You will likely have to do this with the original remote. A universal remote may not allow you to do this.
Posted on Jul 23, 2007
SOURCE: Turning off Closed Captioning
On the 27" TruFlat the closed caption button is hidden within the DVD buttons. You have to press it multiple times to shut off closed caption. It seems to have multiple sources for closed captions. Press the button until no source appears on the screen. ITS CONTROLED AT THE REMOTE CONTROL - NOT ON THE ON-SCREEN TV MENUS. Good Luck
Posted on Nov 28, 2008
  • 520 Answers
SOURCE: How do I get to closed captioning on the TV?
You will need the original remote. The TV/CAP/TEXT button turns it on and off. The CH.1/2 button switches between channel 1 and 2 of the closed captioning.
Posted on Dec 19, 2008
SOURCE: I do not know how to turn off the closed
I have a Samsung 46 in TV. Here are my problems:
1. I do not have the remote that came with the tv.
2. I can't figure out how to get cc off the screen. I have a universal remote with no button for "cc". The directions mention to go into MENU, highlight SETUP menu, Highlight the PREFERENCES menu, then press the SELECT button, highlight the CAPTION menu, then press SELECT. The CAPTION menu appears. Then highlight the setting you wish to change. The Caption item in the Preferences menu alllows you to turn cc on and off.......
The problem is the universal remote does not allow you to use any Preferences menue or Caption menu.....
Suggestions???????????????????????????
Posted on Aug 13, 2009
SOURCE: jvc tv- closed captions, no option to turn off
Hey, on the JVC remote there is also a " C.C. " button
and it's located above the volume. Clicking this will allow you to set
the closed caption to off. you can't turn it off from the menu button.
Cheers
Posted on May 27, 2010
You should have its remote control to shut off the close caption function. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Nov 13, 2014 | Apex Digital Televison & Video
On a Generac model 1646-2 generator is the oil level switch normal open with full oil level.
I don\'t know, but change the switch or bypass it. They give plenty of problems & motor would start sometimes & not others.....Check the oil & rely on old style tech. I bypassed the switch on both of mine.after they gave problems & wouldn\'t run when needed....I only got a second one when I needed power & the switch was the only thing wrong ( I found this out too late.) & ended up with 2....
Jun 19, 2014 | Coleman Powermate Subaru 5000W Portable...
I have an Apex LD3249 LCD TV that the volume go up to 100 on it's own and won't go down, any suggestions on what could be wrong or how to fix it?
The digital volume control section circuit has the fault. You have to check its main digital board. Might need replacement.
Nov 27, 2012 | Apex Digital LD3249 LCD TV
Is there an 800 number I can call o get the factory setting for the smart series Philips magnavox tv? It was manufactured in August of 2003.
Try this number- the unit may have a defect in it and may need repair- you don't say what is wrong with it.
http://www.support.magnavox.com/html/index_us_en.html
Aug 09, 2012 | Philips Remanufactured Magnavox...
I'm trying to connect my LG 32LC7D Flat screen t.v. to my HP G62 Laptop via the hdmi cable. No matter what settings I choose on the t.v.'s menu, it continues to say "no signal". Nothings...
go graphic properties and change frequency hertz to 60hz or on which its compatible.some lcds not copatiable with greater then 75hz frequency. you have to chang this thing for second disply not main setting for your laptop lcd
Jul 11, 2011 | LG 32LC7D Television
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
I have a GE universal remote and none of the apex codes worked on my Apex LCD TC model LD4088
Hello there blondie1091 and a warm welcome to FixYa. I see your having trouble getting your APEX codes to work. Sometimes depending on the remote they either accept three or four digit numbers. Let me give this code to you just in case you don't have the right one. Please see below.
Apex LCD LD4088 Television
Four Digit Code
0156
Three Digit Variation
156
Give both of these a go and hopefully you'll be all sorted out. I hope you found this information helpful and good luck. Thank you for using FixYa.
Apr 26, 2011 | Televison & Video
Recently the picture on regular channels has stripes running through it but when I watch HD channels, the stripes don't appear. What is wrong?
I don't believe the trouble is with your TV. My guess is that you don't have adequate signal for the Analog channels. Make sure all the connections are secure.
Does this also happen when playing DVDs?
Have you contacted your CATV or Satellite provider for assistance?
Apr 22, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Televison & Video Logo
56 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
