Question about Samsung Refrigerators
How do you access the fans(s)that transfer cold air from the freezer coil to the fridge? Samsung RS267TDBP
    Genius:
  • Samsung Master
  • 2,669 Answers
The cold is transferred by the gas coils . there is a fan to cool the hot gas at the compressor . some freezers have a fan to circulate the cold air in the freezer , they don't transfer the cold from the compressor.
Posted on Nov 13, 2014
Testimonial: "On a Side-BY-Side all refrigerator on a Samsung is transferred from freezer via fans. That my question, what is the best way to access them?"
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
  • 74 Answers
SOURCE: side by side GE refrigerator psf26pgta
The fan should be a standard 12v DC computer style fan , test that you are getting voltage to the fan connector . You should also be able to get the fan to run by connecting it to a suitable supply . Once you have eliminated the possibility of fan failure then it gets more involved.
Posted on Aug 28, 2008
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Oct 29, 2017 | Samsung Refrigerators
Samsung refrigerator rs267tdbp nat cold freezer working fine
I had the very same issue. The freezer is actually responsible for cooling the fridge via fans. On the back of the fridge there's an access panel near the top containing 2 boards. The large one is the control bd. Make note of the connections and remove the board. Right where these fans plug in there are 3 switching transistors and a power regulator. Replace all 4. This is a common issue. A good place to get these is at digikey.com. even with shipping they only cost less than $10 USD. Also, on replacement, put a THIN coating of heat sink compound. You can get it at the same place or Radio Shack.
Nov 16, 2013 | Samsung 24.8 Cu. Ft. Side-by-Side...
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Freezer works....fridge doesn't
Your refrigerator gets its cold air from the freezer by way of a fan that transfers air past the freezer coils to the refrigerator. If the fan isn't working the refrigerator will not get cold. I your coils in the freezer are freezing up this will also stop the flow of air to the refrigerator. The first thing to check is the fan.
Most refrigerator/ freezers are only controlled by one compressor (unless its a very expensive model). So if one is cold and the other isn't it's normally a simple problem.
First, check the temperature knob dials. Then check the seal using the dollar bill test or flash light test (described in link below).
You can also unplug the unit for at around twenty-four hours to clear blocked vents. Be sure to place some towels around the unit and prop all the doors open.
Defrosting your fridge should clear up any blockage in the duct as water and gunk often clog up the ducts. While you are at it clean the coils and the inside of your fridge and freezer.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Samsung side by side not as cold as it should be all fans sound like they are working what to look for fridge only 4 years old pulled out back cleaned coil pack with compressor please help
We had a similar problem. SAMSUNG said to not set the freezer to the top range and the fridge to top range. If you set the freezer to the top range there is not enough cold air funneled to the fridge. We usually set the freezer to about 3 dots and the fridge to 4 or 5. Try that and see if it helps
Dec 04, 2009 | Samsung RS2630WW Side by Side Refrigerator
Maytag P MFD2561HEB model the frig is not cold but the freezer is fine. How do we set the frig control?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Refrigerators
My fridge not cold but freezer working fine
there is a shaft from freezer to fridge that the cold air travels. make sure that is unblocked. also make sure the fan is working. then see if the freezer coils are iced up (this restricts air flow). if they are, unplug it, empty the fridge and freezer, defrost the coils, dry it out, plug it in and turn it on (not high). once it reaches the temp and the compressor stops, fill the fridge again.
Jul 30, 2009 | Samsung Refrigerators
Samsung fridge freezer
Jul 30, 2009 | Samsung RB215LASH
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
103 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
