Question about Mitsubishi HC3800 1080p Home Theater DLP Projector Projector
I accidentally turned my projector screen upside down.how can turn it right side up?
I need to flip the image from upside down to the normal right side up position.
    Genius:
  • Mitsubishi Master
  • 2,460 Answers
Are you putting the slides in up side down?.
Posted on Nov 13, 2014
nfandres
  • 168 Answers
SOURCE: Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Posted on Feb 12, 2007
SOURCE: xd70u upside down image no remote how to control with PC
Try the menu feature, then installation, image reverse until it gets to the correct position. Note, the Image Reverse rotates in quarters. You can also access the Menu feature from the projector. It just happened to me and as I was looking for answers and playing around with it, I fixed it!
Good Luck!
Posted on Jul 10, 2010
marsrover
  • 682 Answers
SOURCE: mitsubishi xl8u projector
go to menu and press it---press right or left arrow button and go to installation press enter.
--go down by down arrow to image reverse- use left and right arrow to adjust the image to the correct position.
Posted on Mar 17, 2008
SOURCE: auto shutdown on Mitsubishi XD series projector
Stripped projector ( including removal of bulb ) and cleaned internals
re assembled and all A1
RR
Posted on Aug 24, 2008
SOURCE: xd500u prjector image upside down
Use your remote to access the image menu(menu button). scroll to the Mirror Invert selection. select invert.
Posted on Nov 11, 2012
Image is upside down how do i turn image right side up
Go into the menu then the display option. It's probably set for "ceiling mount"
Nov 13, 2014 | Mitsubishi HC3800 1080p Home Theater DLP...
Image is upside down on the screen
Alot of projectors (being all projectors that are designed to be hung from a roof) have an image flip function. This is because when you install a projector in a roof you have to flip the projector upside down so the projector doesn't have to be pointed down and doesn't cause any problems with keystoning.
If you have just bought a new projector and installed it in the roof or perhaps bought it second hand and are projecting from the floor (when the previous owner may have had it in the roof), you will need to go through the menu screen until you find this setting. I don't know exactly what Epson call this function but it should be in there somewhere. If you have it on the floor you want image flip off, if you have it in the roof you want vertical image flip on, horizontal image flip is for when your projecting onto a special screen surface from behind the screen.
Mar 24, 2011 | Epson PowerLite 3LCD Projector
My project image is flipped horizontally on the screen, but displays normally on my laptop. How do I fix my projector image?
The projector may have a menu function for flipping the image dependent on whether it is merely set on a desk, or mounted upside down on the ceiling. See the manual, printed or online.
Feb 02, 2011 | ViewSonic PJD6211 Projector
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Casting image lower on wall
I don't know the model number for your projector, but most projectors are designed to place the image level with the bottom of the projector, which works great for tabletop mounting but not so great for ceiling mounts.
If you're mounted at ceiling height, try turning the projector upside down to see if it places the image in the right place on your screen. If that fixes it, then use the on-screen menus for your projector to flip the image and you should be all set.
Dec 09, 2009 | Dell Office Equipment & Supplies
I have an eiki xbl20 projector that i mounted upside down. How do I get the image to turn right side up?
Nov 20, 2009 | Eiki LC-XB15 Multimedia Projector
Image upside down
Check in the settings. One of them will have the option to invert the image not sure what it will be called. That should flip it upside right. I had the same issue with my projector when I first got it just messed with menu until i found it.
Feb 11, 2009 | Epson (V13H010L13) Projector Lamp for...
Projector displays reverse image also has grayish purple color
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
Dec 31, 2008 | BenQ PB6100 Multimedia Projector
Picture is upside down
flip the projector over
Apr 30, 2008 | InFocus IN36 Projector
Menu
Hi paulveldt
Very easy ! Simply go into the menu and look for the subfolder that will either read Mirror or Flip Image. Scroll down to it and press left or right until the image is back to normal.
A mountable Projector can project flat fronted ( on a table ) upside down ( on the ceiling ) rear ( from behind - on a rear projection screen ) and upside down from behind ( from the ceiling onto a rear projection screen )
This should do the trick !
Thanks for using Fixya !
Apr 30, 2008 | NEC VT676 Multimedia Projector
Mitsubishi HC3800 1080p Home Theater DLP Projector Projector Logo
419 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
