I plugged usb hard drive into tv but I can not find what to press on remote to find it
    Genius:
  • 2,430 Answers
Did you plug into a usb or hdmi slot? .On the remote press tv input use the up down keys to highlight the slot you are using and press ok.
Posted on Nov 13, 2014
I have a Panasonic tc-50as540c led tv. It has two USB ports on the side. When I plug in a portable hard drive into either of them, the TV doesn't see it. Is there a setting to make this work?
You should find an "input" button on your remote press this and then use the central cursor control to scroll down to the correct input, which is probably "USB". Once there press OK and that should be it!
Jun 29, 2015 | Panasonic Televison & Video
Hello, plugged in my hard drive, error message "USB over current detected" pop up instead :( Any idea?
That is typically a general error seen on many devices.
Normally it means you are plugging in a USB device (your hard drive) and it requires more power than the USB port can put out. Many TV's and DVR's don't like USB powered hard drives, they want hard drives that plug into the wall AC outlet for their power. If your hard drive has a second USB plug, or a AC plug, you will likely have to use them in addition to just plugging the USB cord into the TV.
Aug 29, 2011 | Televison & Video
Hello, When I plug my hard drive into my computer, it does not recognize it until I unplug it. I've tried this on many laptops and it's the same in every case. Then if you loosen the usb, until...
Yes do not format it. Try this and see if it finds your data. http://findandmount.com/
If it does not you need data recovery help. This guy does remote data recovery and only asks for donations. http://FreeDataRecovery.us
Jul 17, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
I wondering only,how to connect my hard drive to the LCD TV
Hello.
If you have an external usb hard drive and usb ports on your tv just plug it in. Sometimes the menu for usb drives pops up. If not, try to press source or input select, input on your tv remote. You must see your drive name in the list. Just select it and you should be able to access your hard drive.
Hope this helps!
Feb 13, 2011 | Computers & Internet
Can't see anything on the tv screen when i turn on my argosi
When connected to the TV, press the "Setup" key on the remote and go to "Preferences".
Now select the option "Factory Default Setting" and press OK. This will solve all the issues.
May 28, 2010 | Argosy HV358T Audio/Video MP4/MP3/...
I have a verbatim media station pro but when i connect it to my T.V and press t.v out on my remote control ,nothing shows up.i used an S-Video cable .but nothing displays on the televison,do i have to...
I'm assuming your TV is set to s-video input already.
Then, p.15 of the users' manual for the Media Station says to press the TV out button several times, each time switches the output between different modes (HDMI, s-video, composite, etc).
Apr 21, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
320 GB Inoi media hard drive will not play on TV
Make sure you are using the original composite cable and check the connections.
If you are using a SCART cable check the connections.
Also make sure the remote control is responding to media player.
Check the drive responds when you press the “STANDBY” button on the remote.
If the drive responds then the remote is working fine. If not change the battery and see whether it helps.
Also try on another TV and see whether it works. If not back up all the data on the drive and format it and see whether it helps.
All the best!
Aug 11, 2009 | INOi 320GB INOI HIGH DEFINITION 7200 RPM...
Bose Remote not linking to Samsung HDTV
I got my bose remote to work when I did a system update on the remote. Turn the TV on. Select the TV video input that connects the system. On the control console, press and hold setup until the system information screen displays. line 5 will display the currently installed console software version. on the remote press any button. Line 10 will display the currently installed remote software version. Do a bose system update. On the control console press setup. on the remote control, press the down arrow until update is highlighted and press ok. make sure yes is highlighed and press ok. on the control console plug a clean usb drive into the usb port.when prompted, remove the usb drive and connect it to a computer. open the drive and double click on the download_launcher file, which should bring you to an update page on bose.com. Once complete, put it back in the control console. When the update is complete remove the usb.
Feb 22, 2009 | Bose RC-28S stereo expansion kit - White...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
