Question about Samsung Refrigerators
What does blinking temp bar lights mean on RS261 side by side. No response from display
Samsung RS261M side by side. Temperature bar only for this model, no digital read outs for temp there for can't find error codes for this model.
  • Samsung Master
  • 3,368 Answers
It is telling you the temperature is out of range. Put a thermometer in it and it should be below 40F 4.5C and above 32F 0C.
Posted on Dec 06, 2014
SOURCE: LG refrigerator error code
Had the same problem + a weird noise, which turned out to be ice build up on the blower fan. Unplugged overnight and then opened the lower back panel. There is a small fan that blows over some small coils at the bottom of the box. There is also a drip pan that should be "full" of water. I sponged out the drip pan, put the panel back on and then plugged back in. Works great.
Posted on Nov 04, 2008
SOURCE: samsung side by side
you can reset the fridge by pushing "Power Freeze" and "Power cool" at the same time
it worked with my fridge Samsung RS21DAMS which stopped after a power cut and was also flashing at the digit of the fridge temp display
Posted on Nov 11, 2008
projdoc
  • 2237 Answers
SOURCE: samsung model rs2577sl. fridge side not working
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 26, 2009
SOURCE: error on the display
hold down power cool and power freeze button together until it resets
Posted on Feb 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
My Samsung RS261M is not producing much ice.. water is working just fine?????
Either the harvest temperature thermistor is bad or the inlet water valve is plugged or malfunctioning. More than likely, it is the inlet water valve assembly.
Mar 01, 2015 | Samsung Refrigerators
Refrigerator malfunction
samsung units have duel cooling. that means there is a evaporator in the freezer and the fresh food section. it is possible that the temp sensor in the refrigerator section could be bad. and they have been known to have defrost problems there to. the samsung is a complicated unit and its hard to describe how to repair since there is a lot of electronics that control everything. the best thing I could say is to unplug the refrigerator for a few minuets. sometimes this will reset everything and start the unit back to the factory settings. if that does not work I would call for service. hope it helped you some
Aug 04, 2007 | Samsung RS2556 Side by Side Refrigerator
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
Samsung NX58F5500SS 30" gas stove 'door' light blinking and temp unregulated
-possibly temperature sensor has bad connection. Or bad sensor.
Good luck
mai
Dec 19, 2013 | Samsung Kitchen Ranges
Error code 5E
The means the temperature is higher then the set temp. Check the door and set the temp higher
Mar 26, 2013 | Samsung RS2630SH Side by Side Refrigerator
What does OF on the display mean?
If you get the message OF on your Samsung refrigerator here is how to correct it. What OF means is your freezer and refrigerator has or is going to stop and warm up. To correct it push the Light+Freezer buttons for 3 seconds. It will reset to the last temp settings and everything should go back to normal.
Feb 06, 2013 | Samsung RS265TDRS Side by Side...
I have a Samsung RS261 fridge whit a blinking light. None of the button selections are working. What does it mean when it's blinking?
It is out of synch. Try unplugging the refrigerator or turn off its circuit breaker for 10 minutes or so to see if it resets itself.
Jan 03, 2013 | Refrigerators
I have a 61 inch Samsung DLP it says stand by temperature what does this mean?
If stand by/temp light blinks it could be: a fan not turnig, back vents blocked (overheating) or DMD/light engine failure.
Apr 11, 2010 | Samsung HLT6187SAX 61" DLP HDTV
Strange code on temperature panel, blinking 88 88/A8 w/no respons
Press both power cool buttons at the same time, until you here a chime (about 3 sec). This should solve the problem.
FIT FiNallee
Dec 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
336 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
