Hi 48 000 btu daytek cassette is running for 10min on cooling then stops running inside and outside and ared light comes on on the indoor what can be the cause
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
SOURCE: AC Compressor running outside but no air coming out of inside vents.
Can you say, WOw, Icould've had a v-8 moment! I think you answered your own question or you are not far from the answer. (let me direct you, either the thermostat or the little door on the duct going to your room! Thank-you-very-much!
Posted on Aug 25, 2008
mastatech
  • 478 Answers
SOURCE: Amana 1 ton Residential AC / Outside unit comes on for a sec
open the service panel to check for control voltage of 24volts when tstat calling, The contactor should be pulled in, if contactor is down,and contacts appear to be clean, and the unit is still not running, it is a bad compressor. to test this unplug the black wire from the compressoror at contactor,w/ power off! Turn on power if fan works normally it's a bad compressor. However if you see a swollen split cap(5 wires to a soup can looking w/ the terminal C,F,and Comp), switch it first and start at square one.
You also need to consider the high pressure switch if its cycling on off on off.
Posted on Mar 12, 2009
  • 127 Answers
SOURCE: ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
Posted on Jun 29, 2009
motor1258
  • 6674 Answers
SOURCE: Duo Therm RV air conditioner inadequate cooling
The rule of thumb is 20F difference (lower) than ambient temperature. Most manufacturers will tell you 20 F degress is about normal. In your case it does sound a little warm, but I need to ask, sorry. Was it working o.k. before in same basic temperatures? Have you cleaned coils & fins good on Evaporator & condenser recently? Have you removed filter inside & cleaned it as well, and looked to see if coils are frosting up by chance? Is this a ducted or non ducted system? I'm guessing on a 5th wheel, it is ducted, so make sure you have good discharge on all of those as well. Any blockage or restriction on the discharge side will also cause the problem. Keep me posted on what you find.
Posted on Sep 01, 2009
Luxpro psd111 thermostat shows snowflake (sometimes blinks), outdoor fan works, but no cool air comes out inside- no air flow at all. Is it the thermostat or an a/c unit malfunction?
If the outdoor unit is running the indoor fan should definitely be running. Turn power off to indoor unit. Put red green and yellow wires together behind the tstat with a wire nut. That is power (red), indoor fan (green), and compressor (yellow.) Turn power back on. This is bypassing the tstat and you should have indoor fan and outside running as well. If yes the problem is in the tstat, if no indoor fan the problem is in the unit. Good Luck!! Let me know!!
Apr 28, 2017 | Heating & Cooling
My Carrier Central Air unit is not working and shows Code: 24 VAC power
Will the indoor unit run with the Thermostat fan switch set on auto?
I need to confirm that the indoor unit runs first.
Jun 03, 2014 | Carrier 38CKC036 Air Conditioner
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
Hi I have a Daytek 12000btu. The air con is blowing out cold air but despite having all windows and doors closed the cold air is not circulating around the room. Its only cold when you stand in front of...
air filter, cooling coil and blower wheel are full of dusty. Clean it. And also check RPM of indoor fan motor. If less replace capacitor. If rpm o.k, after clean run the unit. Thanks.
Feb 09, 2011 | Daewoo DSA-122L Air Conditioner
We have a MXZ-3A30NA that does not seem to be cooling down the house. Indoor temps are reading 75 to 78 degrees and the units are set at 65. We have gone through the book and have followed the check list...
Hi!!
Check the following:
Make sure the filter and the evaporator coil are clean. Also check condenser coil in the outside unit is clean.
When unit is turned on there should be (on the led display, inside unit) one green light on for the blower and another one for the compressor, both lights should be ON untill the unit reaches the preset temp. If the light for the compressor (usually the light on the right side) does not stay ON, check the outside unit.
On the outside unit, check that when turned on, both the fan and the compressor kick in and stay running. If the fan motor stops, the compressor overheats and the thermal proteccion shuts it down to prevent damage. Also, if the R22 gas is low, the low pressure switch prevents the compressor from running.
Good Luck!!
Aug 04, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a whirlpool 24500 btu air conditioner it
It sounds like the thermostat sensing bulb is not sensing indoor air temperature?
Jun 07, 2010 | Heating & Cooling
Condensing unit
the 48 indicates 48,000 btu's. 12,000 btu's = 1 ton of cooling. this unit is a 4 ton condenser
Mar 15, 2008 | Heating & Cooling
No cooling after power out, indicator lights pattern not in manual
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
