Question about Garden
Toro snowblowe car 2450 started first time but after about an hour refuses to start
Fresh gas and oil
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Loosen the gas cap and try again. Many times the Fuzz that grows in the Gas areas due to Ethanol gas can also clog the Gas Tank Vent
Posted on Nov 25, 2014
4 Suggested Answers
SOURCE: i have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Posted on Jan 08, 2010
Testimonial: "Thank you for the quick response."
  • 122 Answers
SOURCE: Toro CCR 2450, Common starting problems? Fresh
Next step would be to check the ignition module(coil),I have a lawnmower that uses the same 2 cycle engine. Check coil for spark by removing the spark plug from the block then connect the insulator side of the sparkplug back to the coil then ground the plug by touching the threaded side to the block away from the sparkplug hole while turning the engine over. Should see a spark, if not you'll need a new coil,not hard to replace. calls for Briggs & Stratton #80-1268 you can also use a Toro/Lawnboy coil #99-2911 or #99-2916 or #684049.
Posted on Feb 02, 2011
  • 16 Answers
SOURCE: My Toro CCR 2450 GTS Snowthrower loses power after
have found that even with self propel mowers-- the brake cable is worn and makes it hard if not impossible to start.
Posted on Nov 30, 2011
I put a mixture of oil gas in my 621 R/621 toro snowblower?
Hi Jerome:
Shouldn't be too bad.
You could disconnect the fuel line at the carb and drain the tank.
Drain and flush the carb. Reconnect the fuel line and fill with fresh gas.
If it won't start, pull the spark plug and clean/dry it with a propane torch, or replace it.
Odds are it will be fine.
Cheers.
Jan 18, 2016 | Toro Power Clear 621 R Snowblower - 38451
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
Toro CCR 2450, Common starting problems? Fresh gas/oil mix. Good compression. Just pulls, no pops or sputters.
Jan 31, 2011 | Toro Lawn Mower With Toro Power Tools
My Toro CCR 2450 GTS Snowthrower loses power after it gets warmed up. New spark plug and fresh gas with proper oil mix.Why?
Mine does same. Wait a half hour, restart, runs good for 20 minutes and slows again. Just had it in for a tune up. Machine is only three years old.
Dec 31, 2010 | Toro Lawn Mower With Toro Power Tools
I have a toro 421 snowblower i filled it up today with oil and gas when I started it a milky white oil looiking came out the breather tube what could have caused this
it sounds like you had water in the crank case.
Stop running it immediately and drain all the oil. Then make sure the crank case is empty of oil and clean, and refill with fresh oil. After you fill it back up with oil, run it a minute and check again for any milky/foamy oil. If it is clean, check it again after several minutes. If it stays clean, you should be good. If it is milky again, take it for professional service, as you probably have a damaged gasket somewhere.
Nov 16, 2010 | Toro Lawn Mower With Toro Power Tools
I have a toro ccr 2450 snowblower. i bought it
Sam
Jan 08, 2010 | Toro Lawn Mower With Toro Power Tools
My 2year old toro 6.0 lawn mower wont work i just took it out from the shed, it was in there during the winter and now wont work. it worked perfect before why is this not working someone told me its debris...
did you burn all the gas out at the end of year last year if not bad gas will leave deposits in the carburator.here is a simple sugestion drain any gas out of it thats in it .put fresh gas in it and 2 table spoons of marvel mystery oil in gas tank you can get it at any auto parts store crank it untill you are sure fresh gas oil mixture is in intake wait an hour and let the fresh gas\oil mix do the work.pull plug dip it in fresh gas put plug back in and try to start it this often works if it dont you could have leaves .dirt .rust .or debris on surface of flywheel ,or a bad sheer pin on flywheel the sheer pin is whar times the engine on most small engines good luck i hope these sugestions help
Apr 29, 2009 | Toro Lawn Mower With Toro Power Tools
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
