Why won;t my Lg air conditioner heater model lw1213hr turn on
It won't turn on
ACTECH
  • 80 Answers
SOURCE: LG LWHD 1200 HR Air/Heater fan will not start.
may be a bad fan motor or loose wire, however some units have dip switch settings on the circuit board preventing the fan from coming on.
Posted on Dec 19, 2007
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
SOURCE: LG air conditioner model LG LP1210BXR
Well it needs to be fix by a professional, so if you or someone you know are good at tinkering go for it. It as a sensor problem at the evaporator.
Posted on Aug 03, 2010
  • 230 Answers
SOURCE: We have a Coleman Evcon
Check your stat. is it set properly on cooling, and low enough to turn the unit on, with power on and the stat calling for cooling you should at least get the fan and the out door to kick on, if not your stat or the transformer could be bad. there is a reset on the transf. on some of the unit that could be tripped
Posted on Jul 04, 2011
  • 4736 Answers
SOURCE: I have a portable air
The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
I hope this helped you and thanks for choosing FixYa.
Posted on Jul 21, 2011
I have a portable air conditioner model LP0711WNR. My issue is when I drain the air conditioner, it only drains about one cup of water. Then, when I turn it back on it and use it, after about an hour it...
Jul 21, 2011 | LG LP0711WNR Portable Air Conditioner
My LG portable AC won't turn on... display says E1 model number LP0910WNR
I have searched all LG data bases for the Model Number(s) you listed and those numbers were not found.
Please recheck the model number and get back to me. So that I can try to help you, again.
Thanks, Rich
Jun 10, 2011 | LG LWHD1000R Portable Air Conditioner
We have an LG model #LWHD-1200HRY. The air is
is it a heater also if so electric/or heatpump.
Jan 15, 2010 | LG Heat cool Window Air Conditioner
When the heater is turn on the generator is draged down. The a/c works fine no problem with the generator.
Unless it is a Heat Pump type Air conditioner, which uses the Compressor to heat, then what is happening is your using electric heat which will pull quite a bit more power.
If you look at the Model number plate on the Ac it should tell you what size heater (KW) you have.
If it is electric you are pulling more amps then the Generator is Possibly made to produce.
Hope this helps.
Nov 03, 2009 | LG Heating & Cooling
LG heater won't stop beeping
turn it off for few meaning turn off from the breaker or plug if has one no power! try that!!
Jun 28, 2009 | GE Zoneline AZ55H07D Air Conditioner
Heater furnace doesn't want to turn on'
Did the fan turn on, if it did when was the last time you cleaned the filter.
Mar 14, 2009 | LG L1004R Air Conditioner
Dec 19, 2007 | LG BG8000ER Air Conditioner
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
