Question about Samsung UN55D7000LFXZA - 55in Led 3d Hdtv 1080p 240hz
SAMSUNG UN55D7000LFXZA with Striped all over the TV.
I had the for a couples of years and it just from nothing, appeared some stripes (vertical) and then it appeared all over. I turned the TV off for a couple of months and turned back again and came back to normal. After a 1 month using it, the stripes came back again. I would like to know was is going on and how can i fix it? I did opened the TV and it had two mother boards. One i think is the power supply and the other must be the main TV mother board. The solution could be replacing the main TV motherboard or is something with the actual screen? Thanks in advanced! Alf C.
    Sergeant:
    Champion:
  • 242 Answers
Time to replace - TVs are throwaway items, replacing motherboards will cost you more than a new one in the end.
Get a new SMART Samsung with a five year warranty and replace when it goes wrong after the five years.
It's a new world out there.
Posted on Nov 13, 2014
4 Suggested Answers
info76732
  • 221 Answers
SOURCE: Vertical hardly noticeable lines appearing on my samsung led tv
If you've cleaned the connexion between the motherboard and the display panel, I'm afraid the likely problem is the display panel.
If you have a friendly local repair shop, they might take a look at it and test with a replacement panel to diagnose the problem.
Posted on Dec 10, 2013
  • 790 Answers
SOURCE: Vertical lines
I would contact customer support and find a manager.
Make him aware that they are dropping the ball.
They are giving you back usede problem equipment.
Posted on May 23, 2014
gopakumarg43
  • 74377 Answers
SOURCE: Trembling and vertical overlay image : how to fix it ?
Main power supply regulator board fault. DC voltage output from it is abnormal. Contact any service technician.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on Jul 30, 2014
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
Main power supply regulator board can cause this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
Why does my lcd tv get stripes on it?
You are about to buy a new TV soon.
Lines have nothing to do with whether you watch XBOX or TV.
Oct 01, 2012 | Televison & Video
My al1916w monitor has a vertical blue stripe on the left side. It works fine except that the striped area discolors video. How do I fix that?
Unfortunately, a stripe on an LCD monitor indicates a physical failure of the LCD panel itself. The only solution is to replace the panel with a new one.
Apr 12, 2011 | Acer AL1916W 19" LCD Monitor
I have a HP 2035 lcd monitor that has a 3cm yellow vertical stripe running though the middle of the screen.
I have smth same... my monitor as gets warm, has a vertical stripe that become blurry, then it becomes worse till the white or black striped, like a zebra line appears? Some electricians have changed the condensators, have put the radiators to reduce the heat, hell knows what is with it, I really like it but no1 can fix it... any1 have any ideas?
Aug 29, 2010 | Computers & Internet
I have an 8 inch wide yellow vertical band in the picture of my 52 inch LCD Samsung TV, what is this? I just moved into my new house a couple of weeks ago and purchased a new 52 inch TV, We are without...
If the band is there within the menu then the screen has a fault. If not then possible signal ghosting issues and a proper aerial should fix that.
Jun 30, 2017 | Televison & Video
LG Flatron L1930B lcd monitor - 3 vert. stripes, center one dead
sounds like the pixel controllers have gone bad or one or more of the color (RGB, RED, GREEN, BLUE) controllers have gone out. this is quite common in lcd monitors/tvs and is usually caused by pressure on the edges of the screen (you grabbed it too tightly when moving the monitor) or just faulty controllers. they are expected to eventually go bad, ask LG for yourself, they will tell you the same thing. If you just bought it, that can be considered a mfr defect that they will replace, IF IT IS IN WARRANTY!!!!! Unfort. there is no fix due to seal that placed on the actual lcd panel inside the plastic casing. Youd spend more money trying to find the part and install it than just buying a new monitor. hate to say it but im an avid gamer and have gone through about 4 lcd monitors in tha past 3 years due to everyday use
Sep 18, 2009 | LG L1930B 19" LCD Monitor
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Black 3-4 inch wide Stripe
this problem is a bad panel it needs to be replaced in some cases the panel is under warranty. check your warranty.
also the E and F buffers could be at fault I would have these replaced first.
Oct 14, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung UN55D7000LFXZA - 55in Led 3d Hdtv 1080p 240hz Logo
Henry  Thomas
Henry Thomas
