Question about Car Audio & Video
How to have both treble and bass thru car auto
I can only hear the bass thru the speakers in my car ater I installed a dula touchscreen mp4 car streo. how can I fix this
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Intelligent re-assembly.
Posted on Dec 21, 2014
5 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
Posted on May 11, 2009
  • 150 Answers
SOURCE: I have a 2005 scion
check your fuse box and find which fuses go to your radio/audio system it may have a built in subwoofer and amp in the vehicle -check those out and hopefully it will solve it.good luck.
Posted on Dec 11, 2010
sean32601
  • 508 Answers
SOURCE: Hello, I just put two
You need new speakers if your using factory ones for sure. Also try adding some tweeters.
Posted on Dec 31, 2010
  • 12 Answers
SOURCE: the bass in my Sony 3-way 6X9 speakers wont work
if these speakers are several years old, chances are that the left one is just blown. could be a loose wire, but if not, it would be cheaper to get new speakers than to get that one fixed
Posted on Oct 19, 2012
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
I've got a 1999 ford expedition with the Mach radio system in it and it does not have any bass playing thru the front or back speakers and i've changed out the factory amp thats in the back where the sub...
does the new amp you have have a hpf setting if so check to see if thats on, turn off the x-over so it will play both lpf and hpf, bass and treble. are all the speakers wired to the amp aswell, this is the only thing that would stop bass other than the head units settings.
Jun 21, 2010 | 1998 Ford Expedition
Bass problems
At the audio mixer settings choose playback and look for something like "for advanced users" or like that. Here you will find the BASS - TREBLE control. In some older audio cards there isn't any selection like that.
Stelios.
Feb 20, 2010 | Inland ProSound 2000 Computer Speakers
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
Bass/Treble balance on Bose Lifestyle 5
You need to go into your menu and set the "MOVIE EQ" to your liking. That is where your bass/treble balance is on a Lifestyle system.
Mar 01, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Feb 18, 2009 | Clarion DXZ375MP CD Player
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
