Question about Dryers
The home thermostat is on "heat" but is blowing cool air. It does not stop when "off" is pressed.
The Hunter Fan Thermostat 44110 has been in our home about seven years, working wonderfully. There is a blinking number 4 on the screen. This has never happened. What could be causing the cold air to be coming through?
    Top Expert:
  • Dryers Master
  • 3,698 Answers
Https://answers.yahoo.com/question/index?qid=20060610162817AAgWgcH
Posted on Nov 17, 2014
  • 52 Answers
SOURCE: Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Posted on Jan 29, 2008
  • 5 Answers
SOURCE: Hunter Fan Company 5 + 2 thermostat #44110 Set and Save/Energy Star
i would say normal, between my family have 3 different hunter models, and they all do it.
Posted on Jul 11, 2008
SOURCE: hunter thermostat 44860
Hit just to the left of the temperature and you will see a fan symbol pop up. Make sure the fan is set to the correct setting. Refresh means the fan will come on every 15 minutes or so no matter what the tempurature. Auto is usually the normal setting I think. Program mode - depends if you have programs. On mode means the fan is always on.
Posted on Oct 22, 2008
Benimur
  • 6966 Answers
SOURCE: Hunter Thermostat fan won't turn off
Hi and welcome to FixYa,
Initially, I am inclined to suspect 3 possibilities:
  • sticking relay contacts (if used) (a possibility, least likely);
  • dusty thermal sensor/switch for the fan (likely);
  • time delay. design feature, will power down the fan only after a certain period that the heater has turned off. This is to dissipate residual heat not only on the heater but on the immediate surroundings of the heater element (most likely).
Good luck and Thank you for using FixYa.
Posted on Jan 01, 2009
SOURCE: Instruction Manual for Model 44860 Hunter Thermostat
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/44002.pdf
Posted on Jan 09, 2009
Can not operate the furance, it just wont come on
Sounds like more is wrong than the thermostat. If gas heat,make sure the pilot light is lit and there is gas pressure.If fuel oil,you may have to press the restart button on the burner unit. or blead the the pump.
Sep 15, 2014 | Hunter Set and Save Programmable...
I have an Hunter Indiglo 44250 thermostat. I changed the batteries and now have nothing on the screen at all. I tried resetting it already and nothing is happening. Thanks!
Having a problem with my fan staying on continuously even after my furnace has finished heating. Cool air blows throughout the house all day and night.
Aug 09, 2010 | Hunter Fan Company 5/1/1 Programmable...
Im replacing my honeywell with a hunter 44110 the honeywell has 6 wires w1 to white, w2 to blk, G to green, RH to Red, Y2 to yellow and Y1 to orange, the hunter only has G RH RC Y W
I hate to tell you this but that thermostat will not work with your system.
The system you have is a 2 stage system and the thermostat you got will only do one stage.
You will need to get a thermostat theat is compatible with stage heating and cooling.
The W1 is the first stage heating, the W2 is second heating. The same is true for Y1 and Y2 on cooling
You could double them up, but it would defeat the encomoy reasons for having a 2 stage unit.
Wish I could give you better news..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44110 programmable thermostat not turning off ac
You may and an anolog stat and the old one was digital if so it won't work. Digital sends info to system anolog is just a set of points open or closed. Digital can carry tons of info to system like a computer. Like comparing a computer to a rock. Sorry but you need to go back to proper type stat.
Jun 30, 2009 | Heating & Cooling
New thermostat not starting compressor
With the jumper inplace does the compressor start? What about without? Unless you have more than one transformer you should leavethe jumper.
Dec 06, 2008 | Heating & Cooling
THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Nov 01, 2008 | Hunter Fan Company 5/1/1 Programmable...
Trying to put a new thermostat on my furness , my furness is a GSC90904CXA the new thermostat is a Hunter 44110. I need help hooking up the thermostat.
I'm not familiar with that model # but most furnaces are similar. R goes to R (usually the red wire). If you don't have a seperate heat source, like a boiler, the wire needs to connect to both Rc & Rh. Stats usually come with a jumper in place. Then W to W (usually white), G to G (usually green) and Y to Y (usually yellow or blue). Before you make any connections, TURN OFF YOUR FURNACE. If you don't, you'll probably blow the fuse on the control board, or worse yet, blow your transformer.
Oct 16, 2008 | Goodman Heating & Cooling
Jul 04, 2008 | Hunter Fan Company 5/1/1 Programmable...
Location of reset button on model 44110
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Feb 09, 2008 | Hunter Fan Company 5/1/1 Programmable...
Dryers Logo
124 people viewed this question
Top Dryers Experts
