How to dismantle the top covers
When I Lift the printer cover to high and causes the cover hinge socket broken.
    Habit-Forming:
  • 91 Answers
What kind of printer you mean ?
Posted on Nov 13, 2014
Soulvisitor
  • 1113 Answers
SOURCE: How to replace broken hinge on ADF on Brother MFC-8820D printer
Look at back of machine and at your new hinge, note the screw hole, if you undo both of those on the back of the printer, entire doc feed will come up and out, BECAREFULL just lift A LITTLE is enough to enable hinge base to be free of sockets (many cables attached) and place doc unit slightly sideways on copy glass to enable yourself access to 3 screws that hold hinge.
Posted on Jan 05, 2008
SOURCE: top cover open error when printing
I had the same problem and fixed it by sticking the end of a pen (the writing part) in the hole on the right side when you open the top cover.
In other words if you open the top cover and look on the top cover you will see a tab that goes into a hole(the hole is next to the picture of the print cartridges). There is a hole with switch/tab(I don't know the proper terminology) on it that is activated when you close the top cover. If you stick the end of a pen in that hole it should activate something and the print cartridges will start to make noise and move around. You can then close the cover and it should close all the way.
You can then try to print a test page.
Good Luck
Posted on Dec 29, 2008
  • 11 Answers
SOURCE: Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Posted on Jun 13, 2010
  • 42 Answers
SOURCE: HP officejet 6210 broken hinge on cover to access
The 6210 series are famous for broken hinges, plastic and under spring loading. One place has them but at $88 for a set it may be not worth it. See link below if interested. I have one too with same problem.
http://www.everprint.com/online/SimDetail.asp?partno=q8052-40001
Posted on Apr 06, 2011
  • 12 Answers
SOURCE: mess. saying cover open i cant seem to close the
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Posted on Oct 20, 2011
Acer aspire 5253 power button broken due to hinge
Have a repair shop or person look at this---it may be fixable now but if you keep using it the issue may get worse.
Nov 05, 2012 | Acer Aspire 5532 15.6" Laptop Original...
Lexmark x6570 hinge is messed up so im getting cover open message
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to push it back into place with no luck.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover of the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
Oct 05, 2011 | Lexmark X6570 InkJet Printer
The scanner lid won't close properly. I see the right back corner of the lid has popped out of it's socket. how can I fix this?
Aug 26, 2011 | Lexmark X3470 All-In-One InkJet Printer
Hinge is broken on my lexmark X6500 so cover won't close
Jul 23, 2011 | Lexmark X6570 InkJet Printer
Mess. saying cover open i cant seem to close the top down. the top cover seem to be off track or broken
Feb 05, 2011 | Lexmark X6570 InkJet Printer
Can't close doc cover properly - seems 'broken' at hinge - can I fix this myself?
The left hinge breaks often enough that Brother changed the part number of the part. I hope that means the new part is stronger; I haven't seen one come back for a second repair. Assuming it's the larger, left hinge that's broken (It always is.), you need an LP2403001 HINGE ASSY L. You can find it from a servicing dealer or online, and it's easy to replace.
Look at the back of the machine and find two large phillips screws in holes. They keep the hinge blocks from coming up all the way out of the machine. Remove both of them and lift the top cover up until it's connected only by its cable. It might take a helper to hold the cover, but you need to unscrew the hinge assy. from the top. The three screws are obvious and easy to reach now that the cover is loose. Put the new hinge on, lower the top back down so the hinges drop into their holes, and put those screws back into the holes in back. You're done.
Jul 11, 2010 | Brother MFC 8820D All-In-One Laser Printer
Can not get saddle bag open the lach is messed up and won't open
The solution to this problem, unfortunately, will involve the destruction of two hinge pins; since the hinge is sold only as an assembly, the entire hinge will have to be replaced. I'm sorry about that, but I thought you ought to know that before you start the repair.
Look at each end of the hinge (on the outside of the bag); you will notice a hole and (it may take a flashlight to see it) the end of a hinge pin within. Those hinge pins will have to be driven toward the center of the hinge until the hinge halves separate; that's much less than an inch, but is SEEMS more like 30 feet. Use a nail set that fits loosely in the hole, or a hardened nail about the same size with the tip ground flat.
Once the hinge halves separate, you'll find that you can lift that side of the saddlebag cover only a very short distance; the nylon fabric hinge cover on the inside keeps the cover from opening more than a VERY few inches. The hinge cover is secured by 3mm hex bolts; use a 3mm allen wrench to remove the bolts and the saddlebag top should swing open far enough for you to get your hand inside.
Take a flashlight and examine high on the opposite side of the saddlebag, inside the bag just underneath the cover; there are two catches covered by a broad plastic shield. Use your 3mm allen to remove the plastic shield, then use a small socket to remove the bolts holding the catches to the bottom part of the saddlebag. You can now lift the top of the saddlebag off and reveal the bottom of the catch.
The cover of the catch is secured by 1/4-turn fasteners, you'll see the phillips-head slots. Turn the screwheads until all fasteners are obviously loose; the cover can then be removed. There is a bent catch actuator arm beneath; push the top (free end, well, actually MIDDLE) of the arm toward the outside of the saddlebag cover, and the catches you removed from the saddlebag can be freed and remounted on the saddlebag.
You'll see the bottom of the release button through the catch actuator assembly; push it out, back to its' normal position. You're likely to find one of two things wrong: the actuator arm (4XY-2841A-00-00) is bent or broken, or the lock assembly (4XY-W2843-00-00) has a bent or broken actuator tab or lever. A bolt may also be missing from either the actuator arm or lock assemblies; that would typically cause misalignment or binding.
Replace the hinge, reassemble the saddlebag top with the appropriate repair parts, mount and take a nice, long ride to relieve the frustration.
Mar 17, 2010 | 2006 Yamaha Royal Star Venture
Printer cover
Jul 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
Cover open Error message
I'd say maybe the switchs is broken and your machine reminds me of a lexmark fault. Look for the cover switch, under lid on base, at rear, small hole, find the switch that get's activated when openning and closing the top, maybe it is missing, or broken.
link to lexmark fault, that I think you will find your answer.
Feb 06, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Jan 05, 2008 | Brother MFC-8840D All-In-One Laser Printer
23 people viewed this question
jasbo
jasbo
