WHAT COULD BE THE POSSIBLE PROBLEM IF YOUR PC DOESN'T START ANYMORE . WHEN I TOUCH THE POWER BUTTON THE COMPUTER WON'T TURN ON HWY??
IT DOES'NT START ANYMORE .... WHEN I PRESS THE BUTTON THERE IS NO SWITCHING AT ALL WHAT SHOULD I DO??? I REALLY NEED YOUR HELP ... I NEED TO START WORKING ..
    Master:
  • 464 Answers
Either a bad power supply. In case of lightning strike, the entire motherboard could be toast as well.
Posted on Nov 13, 2014
Benimur
  • 6966 Answers
SOURCE: OVERCLOCKING
Hi, On other motherboard models of Asus, similar problem was corrected by: 1. Updating the BIOS; 2. Actually overclocking the FSB to slightly higher than default (say 170 or 175 from 166, 140 to 150 from 133); 3. Slightly increasing the default processor voltage supply by increments of 0.05; 4. Replacing the 3.0 volts Lithium battery; 5. Replacing the memory to next higher speed; Never had problems like this with MSI, ECS or Intel boards. Hope this be of some idea/help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
ChipcircuiT
  • 157 Answers
SOURCE: PC start directly
reset the bios jumper
Posted on Mar 03, 2009
SOURCE: when turn on BIOS wouldn't load until i press restart
you are having problem with the connector i;e power button try at some good repairing shop
Posted on May 27, 2009
kamal1984
  • 1383 Answers
SOURCE: START UP PROBLEM
You need to reset bios.
Open cpu cabinet and pull cmos cell from motherbord chipset for 15 minutes then all settings are factory defaults.
Aslo you can reset settings with jumper settings .
Refix your RAM memory. Refix processor.
Reattch ATX power supply to motherbord.
Thanks for using fixya.
Please rate solution if it helps.
Posted on Jul 20, 2009
damnor01
  • 1179 Answers
SOURCE: My pc[INTEL DG43GT motherboard] doesnt
Your computer should be switched off at the plug only, the switch on the computer power supply can remain on. No damage will occur. This means that to turn your computer on all you need to do is plug it in, power on at the plug and then push the switch on the computer to turn it on.
I have seen this problem before, I am not sure if it the power supply that is causing this problem. I use Cooler Master they perform well and are priced right.
damnor01
Posted on Nov 15, 2010
IPOD TOUCH WONT TURN ON
Marclla, Check the attached links,instruction and guides to get IPOD up and running, Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
My iPod Touch 5th generation won turn on
If your iPhone iPad or iPod touch doesn respond or won turn on
Fix iPod won turn on problem Quick Fix
http://ccm.net/forum/affich-786664-5th-generation-ipod-won-t-turn-on
Apr 01, 2016 | Apple iPod touch
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Hi Jaspher,
That could me allmost everything..
Are there any lights flashing or on?
Check the cables at the back of the PC and also check if there still is power on the outlets.
Nov 12, 2014 | Computers & Internet
Ibuypower won't boot
Unplug the computer, Hold down the power button for 5 seconds.
Plug the computer in. Power on the computer.
Call, text or email Shane 801.554.4142 / rsownbey@msn.com
Apr 27, 2013 | Computers & Internet
I have a 1998 4wd automatic toyota 4runner and it won't start. The engine turns but won't "ignite" the engine light and A/T oil temp light appear on dashboard. any suggestions on what to check
Hi Nikki, What oil was low? Was it engine oil or gear box oil? Did the engine overheat? what exactly happened? Did you hear any strange noises when the engine stopped? Was the vehicle towed or was it on the back of a recovery vehicle? If it was towed, at what speed and over what distance? What engine is fitted? Is it petrol or diesel powered? Give as many details as possible to help us help you. Regards John
Dec 22, 2012 | 1998 Toyota 4Runner
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
I dnt knw its nt starting it just show apple symbol n its nt getting switch off also nt even charging
I would first try doing a soft reset by pushing and holding both the power button and the home button at the same time, continue holding until the apple logo reappears, then wait to see if it boots up. If that doesn't work, try doing a restore by plugging into PC and clicking on restore in iTunes on your PC. If this doesn't resolve your problem, call 1-800-MYIPHONE to set up an appointment in an Apple store so a tech can repair your device. Hope this helps!
Apr 26, 2011 | Apple iPhone 3G
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
