Question about Belkin (F5L001) Laptop Cooler
How do I start the cooling fan?
I have it plugged in to laptop nothing happens and I am not a wiz on th e computer just so you know lol
  • 33 Answers
Hi! it should start automatically so you can try carefully tap from the bottom on the cooler if that wont help check your usb Bios settings.
Posted on Nov 15, 2014
My Lap top cooler stopped working. When I plug it up nothing happens...
The fan may have failed, you will have to replace the fan or cooler. Check to see if there are any loose wires.
May 02, 2011 | Antec (NOTEBOOKCOOL) Laptop Cooler
My 4 year old Acer Aspire 5520 notebook shuts off on me at random time periods. I try keeping it proped up and keeping it cool but that doesnt even seen to help. It doesnt over heat but just decides to...
Have you cleaned the cpu fan? The computer has a cpu fan that can get dirty over time. It's job is to keep the cpu cool. When the cpu overheats, the computer senses it and shuts it down immediately, to prevent permanent damage to the cpu. You can clean it by blowing compressed air into it, and should do that every few months, as routine maintenance. This is the most common thing that shuts a laptop down, other problems involve repair, so try this first. I bough a $7 three inch fan at Walmart to help cool the laptop, and when I run it, I never have it shut down on me, but once in awhile it will without the fan, especially when I play dvds or videos, which really work th' heck out of the cpu. There are also commercial laptop cooling devices, but my little fan works just fine. The other thing that could be happening is some problem with windows, which is something I couldn't begin to guess. Hope it's just a bit too much heat.
Mar 29, 2010 | Acer Aspire 5520-5908 Notebook
My dell inspiron 1525 keeps turning off and shutting down without me doing anything. why?
The computer has a cpu fan that can get dirty over time. It's job is to keep the cpu cool. When the cpu overheats, the computer senses it and shuts it down immediately, to prevent permanent damage to the cpu. You can clean it by blowing compressed air into it, and should do that every few months, as routine maintenance. This is the most common thing that shuts a laptop down, other problems involve repair, so try this first. I bough a $7 three inch fan at Walmart to help cool the laptop, and when I run it, I never have it shut down on me, but once in awhile it will without the fan, especially when I play dvds or videos, which really work th' heck out of the cpu. There are also commercial laptop cooling devices, but my little fan works just fine. Hope this helps.
Mar 29, 2010 | Dell Inspiron 1525 Notebook
Dell precision m90 overheats randomly
Either your motherboard has gone bad, or you fan AND cooling grid needs replacement. The grid is simply a series of metal bars, so to speak, which absorb heat to be passed out of your system with the cooling fan. The cooling fan has 2 speeds. If the system is not kicking in the higher speed on the fan, it's more than likely a bad motherboard. Also, make sure you keep your laptop plugged into the wall as much as possible. Going on battery alone does slow down the processor considerably to conserve the battery.
Best wishes.
Feb 23, 2010 | Dell Precision 360 Workstation/Personal...
Toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
May 18, 2009 | Toshiba A70-S256 Notebook
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Volvo Cooling sensor / fan arent working
Take it one step at a time. First, replace the coolant sensor and try to get the car to start WITH the sensor connected. Make sure that you DO NOT use any teflon tape when installing the switch (this will isolate the switch which will not ground it, making it not work). Th computer receives signals from numerous sensors, and makes adjustments according to inputs received. When the computer gets a signal that the car is still cold, it will adjust the fuel/air ratio to make it run richer (more fuel than air). Once the car is running it will run rough due to a improper mixture since the computer is never sensing the car is warmed up since the sensor is unplugged. This will also account for the slow start due to a richer fuel mixture.
Aug 12, 2008 | 2002 Volvo S60
Loud fan, monitor blinks & goes black
The fan can be cleaned. You may want to take it into a computer repair store and get it done as well as inspection of it. Noisy fans are caused by dust in the bearings. In most cases, this can create the noise since the bearing are being grinded down.
Aug 04, 2008 | Acer Aspire 5100-5022 Notebook
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 The most secure way to keep your important business data safe online on Cloud backup for easy access anytime anywhere. Apt for businesses of all sizes and also pocket friendly. If you need your life to be sorted out from all the trouble of managing the enormous amount of data that is being generated every day in businesses whether small or large, then look no further because business online backup service of Dataalign is all you need to keep all important data safe and accessible. We at Dataalign provide companies and businesses a unique and easy way to save their essential statistics, facts and information related to different clients securely encrypted on a safe Business Server Data Backup system which allows them to analyze and download their saved data anytime from the saved storage with just a click of the mouse. One of the most distinct and advanced feature of Dataalign Online Cloud Backup is that it makes all your searches easy with the use of artificial intelligence due to which any file or photograph can be accessed by just typing a name or phrase even if you don't remember the particular name of that file. This results from Computer Data Backup smartly and orderly organized documents for easy sorting and categorizing in order of file size, type, owner name, date of creation etc. You never have to worry about the security of your crucially important data on our business as access to all data is restricted only for the person intended. This system provides security and the freedom of choosing who can view all that data. One more feature of this that helps in Business Server Data Backup making our lives more convenient is the choice for the number of days for which you want to keep a data saved on the online storage so that it automatically gets deleted after that, for saving your extra effort of sorting all your data and getting rid of unwanted files and photos to save space for more important data. So, for making your lives less complicated and more sorted contact our toll free helpline number 888 784-9316 for any assistance regarding business online backup.
Jun 23, 2018 | The Computers & Internet
See all Belkin (F5L001) Laptop Cooler Questions
Belkin (F5L001) Laptop Cooler Logo
96 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
