Question about Verona 36" Single Oven Dual Fuel Range VEFSGE365SS
Do you need an pressure regulator for Verona dual fuel stove other than the one with thw stove.
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Oven fan will not shut off
Do a search for thermal fuse and your model. The heat can trip a fuse which will lock the fan on. Good news is it is resettable. Find the fuse and reset it.
Oct 31, 2013 | Verona Cooktops
I just installled a Verona VEFSGE 365 dual fuel range/oven.
Got to your manufacturers instructions and check if you have a auto cook timer for the ovens, if so normally the timer needs to be set on "Manual" to enable it to function.
Apr 29, 2013 | Verona VEFSGE365DAW 36" Double Oven Dual...
Fame to low on my whirlpool stove
You mean the flame is low. You need to clean the burner jet hole orifice and also check if their is a gas pressure regulator which you can adjust the pressure a lithe more higher.
May 10, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
Gas is not coming in my stove
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 03, 2011 | Jenn-Air 35 in. JGC9536 Gas Cooktop
How can I adjust the flame on the simmer burner to be lower? It seems to be too much flame for a simmer. Otherwise cook top is working great.
Where the gas comes into the stove, there is a regulator. Have a service person check the incomeing gas pressure after the regulator with a manometer. Sounds like you are getting too much gas pressure to the range.
heatman101
May 23, 2011 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
New lp gas reg needed
hello Michael - I recommend that you call your propane provider. They will be able to help you.
please rate my answer. thanks
Jan 22, 2009 | Dacor Preference SGM365SS Gas Cooktop
Converting Dacor ERD30S06CH/LP/H to Natural Gas
I know they won't convert gas water heaters but I didn't know they were afraid of stoves. See if your gas company will help. Sometimes they can drill out the orfices. Some of the older repair people still remember how to do this. The orfice for natural gas is larger as the pressure is a lot less. The gas pressure regulator will also need to be replaced. This can be done with a generic part.
Jul 12, 2008 | Dacor Preference SGM365SS Gas Cooktop
Gas burner not getting enough gas
It sounds like a bad pressure regulator. Or it may be adjusted for LP gas. I need more information. Sometimes you can adjust it yourself, sometimes you need to buy a kit or new regulator.
May 18, 2008 | Cooktops
Verona 36" Single Oven Dual Fuel Range VEFSGE365SS Logo
Top Verona Cooktops Experts
Steve
Bosse Photos
Pierre Legault
Are you a Verona Cooktop Expert? Answer questions, earn points and help others
