Question about Husqvarna Garden
How to repair the the brake on a 395xp. illustrations on how to install the springs. thanks
How to install the spring that goes into the brake handle. i can't find the proper illustration on how its installed
  • Husqvarna Master
  • 1,807 Answers
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 136 chain brake handle spring.
You can get an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
I don't think this has the detail you need.
If it were me I'd visit my friendly neighborhood Husky chainsaw seller (not Big Box Store) and ask to look at the clutch cover with the brake installed (take a camera). I'd probably ask for a quote for their repair too. HTH
Lou
Your model is no longer sold. The seller will know what model replaced it and may be willing to explain the repair procedure for your saw you. Take the cover and loose parts with you.
Posted on Sep 07, 2009
I have a spring missing off thr trottlebecause of this i can not get full throttle where doesthis spring go
There are typically two springs connected to the throttle linkage. One is on the carb, and one is in the handle. Those springs are meant to shut the throttle down when you let go of the trigger. The one that could cause the problem you are describing would most likely be the one in the handle. If that one becomes dislodged, is installed incorrectly, or is jammed by a piece of debris it could limit how far you are able to pull the trigger. If you are not able to press the trigger fully into the handle, then that is where I would check. If you are able to press the trigger all the way, then the problem is elsewhere.
If you are saying the spring is missing because it is no longer inside the saw, please describe it the best you can, and I will do my best to give a more precise location for installing it.
Wasn't able to get Poulan's online manuals to load for me, but perhaps you'll have better luck.
Here is the web site:
http://www.poulan.com/
Select Download Manual
Select Illustrated Parts List and enter the model number for your saw. (It looked like there may have been two or three different models called wild thing.)
The Poulan manual will give you a detailed breakdown of every part in your saw, and where it goes.
Sep 26, 2011 | Poulan 18" Wild Thing Chainsaw
Parking brake cable stretched beyond adjustment how do you replace
Rear Brake Shoes- You'll need to know how to remove the rear brake shoes to remove the parking brake cable. REMOVAL AND INSTALLATION Amigo and Rodeo
  1. Raise and safely support the vehicle.
  2. Remove the rear wheels.
  3. Remove the brake drums.
  4. Remove the brake return springs.
  5. Remove the leading shoe holding pin and spring, and then the leading shoe.
  6. Remove the self-adjuster and the adjuster lever.
  7. Remove the trailing shoe holding pin and spring.
  8. Disconnect the parking brake cable from the trailing shoe and remove the trailing shoe. Remove the parking brake lever from the trailing shoe. To install:
  9. Attach the parking brake lever to the trailing shoe.
  10. Connect the parking brake cable to the parking brake lever.
  11. Apply a thin coat of high temperature grease to the shoe contact points on the brake backing plate (locations A and C in the accompanying illustration), piston contact surface (B), and self-adjuster (D). Fig. 1: Exploded view of the rear drum brakes — Amigo and Rodeo 93026g56.gif
  12. Position the trailing shoe on the backing plate and install the hold-down pin, spring, and retainer. Don't stretch the return spring when fitting the shoes onto the backing plate.
  13. Connect the upper return spring and the leading shoe to the trailing shoe and position the leading brake shoe on the backing plate.
  14. Install the adjuster assembly and the hold-down pin, spring, and retainer.
  15. Use a brake spring tool to install the lower return spring.
  16. Install the self-adjuster lever and adjuster spring.
  17. Adjust the shoe-to-drum clearance to 0.0098–0.0157 in. (0.25–0.40mm) and install the brake drum.
  18. Check the brake drum for scoring or other wear. Machine or replace as necessary. Check the maximum brake drum diameter specification when machining.
  19. Install the rear wheels. Lower the vehicle.
  20. Road-test the vehicle.
Aug 17, 2010 | 1997 Isuzu Rodeo
Change drum brakes
Brake Shoe: Service and Repair
REMOVAL
1. Raise vehicle and remove rear wheels.
2. Remove and discard spring nuts securing drums to wheel studs.
3. Remove brake drums.
NOTE: If drums prove difficult to remove, retract brake shoes. Remove access plug at the rear of backing plate and back off adjuster screw with
brake tool and screwdriver.
4. Remove U-clip and washer securing adjuster cable to parking brake lever.
5. Remove primary and secondary return springs from anchor pin with brake spring pliers.
6. Remove hold-down springs, retainers and pins with standard retaining spring tool.
7. Install spring clamps on wheel cylinders to hold pistons in place.
8. Remove adjuster lever, adjuster screw and spring.
9. Remove adjuster cable and cable guide.
10. Remove brake shoes and parking brake strut.
11. Disconnect cable from parking brake lever and remove lever.
INSTALLATION
1. Clean support plate with brake cleaner.
2. If new drums are being installed, remove protective coating with carburetor cleaner or brake cleaner.
3. Clean and lubricate anchor pin with light coat of Mopar multi-mileage grease.
4. Apply multi-purpose grease to brake shoe contact surfaces of support plate.
5. Lubricate adjuster screw threads and pivot with spray lube.
6. Attach parking brake lever to secondary brake shoe. Use new washer and U-clip to secure lever.
7. Remove wheel cylinder clamps.
8. Attach parking brake cable to lever.
9. Install brake shoes on support plate. Secure shoes with new hold-down springs, pins and retainers.
10. Install parking brake strut and spring.
11. Install guide plate and adjuster cable on anchor pin.
12. Install primary and secondary return springs.
13. Install adjuster cable guide on secondary shoe.
14. Lubricate and assemble adjuster screw.
15. Install adjuster screw, spring and lever and connect to adjuster cable.
16. Adjust shoes to drum.
17. Install wheel/tire assemblies and lower vehicle.
18. Verify firm brake pedal before moving vehicle.
Aug 12, 2009 | 1997 Jeep Cherokee Country
HusqvarnaUSA.com
Lou
Jun 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain brake Assembly
A drawing of a Poulan Wildthing can be found here:
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-1/75.2375-Gas-Saw-Type-1.1.59.1.html
Click "
View the illustrated parts list [Go]"
There are multiple drawings, this one may not be the correct one. The detail isn't very good but this is the best illustration for your saw. The "Handle, Chassis, and Bar Assembly" shows what is available. GL
Lou
May 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Not sure where part goes
if it is a large spring it might slip over the gas line to insalate it on the burner end
Dec 11, 2008 | Brinkmann 815-3786-0 Turkey Fryer
Rear brakes scrubbing on 1998 chevy venture van
Removal Procedure Tools RequiredJ 38400
Caution: Keep fingers away from rear brake shoe springs to prevent fingers from being pinched between spring and shoe web or spring and backing plate.
  1. Remove the brake drum. Refer to Brake Drum Replacement
    Notice: Do not over stretch the adjuster spring. Damage can occur if the spring is over stretched.
  3. Use the J 38400 in order remove the adjuster spring (1). Disengage the adjuster spring loop from the tab on the adjuster actuator.
  4. 2.1. Remove the loop end of the adjuster spring from the adjuster actuator. 2.2. Remove the straight end of the adjuster spring from the secondary brake shoe.
  5. Use the J 38400 in order to spread the brake shoes apart.
  6. Remove the adjuster.
Installation Procedure
  1. Use the J 38400 in order to spread the brake shoes apart.
    Important: Ensure that the adjuster (2) engages the brake shoes (4 and 5), the park brake actuator (3), and the adjuster actuator (1) properly.
  3. Install the adjuster.
  5. Install the adjuster spring (1).
  6. 3.1. Install the straight end of the adjuster spring into the secondary brake shoe. 3.2. Install the loop end of the adjuster spring to the adjuster actuator.
  7. Install the brake drum.
Dec 06, 2008 | 1999 Chevrolet Venture
Reset chainsaw brake on a husqvarna 455 rancher
You removed the cover while the chain brake was in the locked position.  The plier method will be a pain in the ***, as you cannot get enough leverage to twist lock or spread the spring.   I've accidently done this myself and found a much easier way to solve the problem.  Just remove the chain brake handle by unscrewing 2 screws.  Stick the cover and the handle together as they would if it was correctly assembled and twist.  You should be able to unlock the chain brake and it will now slide right on.
Oct 03, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Changing rear drum brakes ona 1999 chevy dually
INSTALLATION PROCEDURE
  1. Install the parking brake lever (2).
  2. Install the spring washer (3). The concave side of the spring washer should face the parking brake lever.
  3. Install the pin (4).
  4. Install the retaining ring (16).
  5. Install the adjuster pin (12) in the shoe (15) so the pin projects 6.8 to 7.0 mm (0.268 to 0.276 inch) from the side of the shoe web where the adjuster actuator is installed.
  6. Apply brake lubricant or equivalent to the threads of the adjuster screw (14) and inside diameter and face of the socket (7). Adequate lubrication is achieved when there is a continuous bead of lubricant at the open end of the adjuster nut (10) and the socket (7) when the threads are fully engaged.
  7. Install the upper return spring (5).
    • Lay the shoes (1 and 15) on a clean, flat work surface in the position they will be in when installed on the backing plate.
    • The shoe with the parking brake lever goes to the rear of the vehicle.
NOTICE: Do not over-stretch the upper return spring. Damage can occur if it is stretched to more than 204.2 mm (8.04 inches) .
  1. Install the adjusting screw assembly.
  1. Lubricate the shoe pads on the backing plate with a thin coat of white lithium grease.
  2. Install the shoe and lining assemblies (1 and 15).
  3. Install the upper return spring (5).
  4. Install the adjusting screw assembly.
    • Do not damage the wheel cylinder boots.
    • Overlap the bottoms of the shoes so the upper shoe ends clear the wheel cylinder boots.
    • Make sure the upper shoe ends rest on the wheel cylinder piston ends.
    • Do not place the lower shoe web ends under the anchor plate until the lower return spring is installed.
NOTICE: Do not over-stretch the lower return spring. Damage can occur if it is stretched to more than 107.3 mm (4.22 inches) .
  1. Install the lower return spring (6).
    • Bring the ends of the shoe and lining assemblies (1 and 15) together over the anchor plate.
    • Hook the spring ends to the shoe web holes.
    • Spread the lower ends of the shoe and the lining assemblies to clear the anchor plate.
    • Position the shoes against the backing plate and release them.
    • Pull the spring into the groove at the bottom of the anchor plate.
  1. Connect the hold-down pins and the spring assemblies (8).
  2. Install the adjuster actuator (11) over the end of the adjuster pin (12) so the top leg engages the notch in the adjuster screw. NOTICE: Do not over-stretch the actuator spring. Damage can occur if it is stretched to more than 83 mm (3.27 inches) .
  3. Install the actuator spring (13). The free end of the adjuster actuator (11) must engage the notch of the adjuster nut.
  4. Connect the parking brake cable to the parking brake lever (2).
  5. Install the drum. Align the marks made during disassembly.
  6. Adjust the rear brakes.
  7. Install the tire and the wheel. Align the marks made during disassembly.
Jul 21, 2008 | 1999 Chevrolet 3500
Garden Logo
47 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
