Question about SUMAS Media SM-310T 3" Digital Wide Touch Screen Car Stereo DVD
<!-- from fixya rte -->Where does the grey ground wire hook? - SUMAS Media SM-310T 3" Digital Wide Touch Screen Car Stereo DVD
Pionner avh-x2550bt wiering diagram
Red=ignition
Yellow=memory or constant power
Orange=illumination
Black=ground
Blue/blue w/white=Amp remote
Speakers are white/white w/stripe= front left
grey/grey w/stripe =front right
purple/purple w/stripe rear left
Green/green w/stripe rear right
If its a dvd player one wire will be for brake "ground" (have to be in park in order to watch movie unless bypassed)
Jul 11, 2016 | Car Audio & Video
I'm trying to hook up a Kenwood kdc x492 to a 96
Battery is yellow
Accessory is white/red
Ground is black
Illumination is red/black
Power antenna is yellow/white
LF speaker +blue/green - grey/black
RF speaker +red/green - brown/black
LR speaker +blue/yellow -grey/white
RR speaker+red/yellow -brown/white
Feb 11, 2013 | Car Audio & Video
Im trying to install an after market radio(pioneer) in my 83 impala. i know i hooked up speakers correctly. But i have a yellow black and grey wire on car wires and yellow black and red on harness. I know...
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Here you go. This is listed for an 85 to 89 Impala, but should still hold true.
May 30, 2011 | Pioneer Car Audio & Video
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
Ive got the red power wire hook up and the yellow 12v hot all the time but dont now what color the ground wire is or the speekers are
Your ground wire is going to be black. Your normal wire colors are violet and violet/black, green and green/black, white and white/black, last but not least you have grey and grey/black. Those are your speaker wires. Solid blue is usually to power your antenna, and blue/white is for your amp turn on lead. Those two wires are approximately .5mV of power, and you can actually use either one to turn an amp on. Speakers: normally your solid color is positive, while the black stripe is your negative. As for which one goes to which speaker, left front is white, right front is gray, left rear is green, and right rear is violet. Hope this helps.
May 17, 2010 | Car Audio & Video
Need a wiring diagram for a sony cdx-gt08 it is going into a 2000 saturn sl2 I have the new wiring harness but need to know what wires go where
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Mar 13, 2010 | Sony XPLOD CDX-GT200 CD Player
How to install Scosche - 2-Channel Adjustable Line-Out Converter
If it is an active converter and not passive, you should have three power wires, black goes to ground, yellow to battery, and red to the remote/amp (blue) wire off the deck. Then there should be four input wires. These connect to your speakers, white-white/black to left, grey-grey/black to right. Black line indicates ground, or (-). Then simply hook up the RCA jacks to your amp! Caution: the Scosche only accepts 80w of power, 40 per channel. Otherwise you rick blowing the converter, possibly the amp (usually a mosfet), and then possibly the subs, though not likely.
Mar 05, 2010 | 1999 Ford Explorer
How do i hook up the power wires on a audiovox pav-1510dtv
to hook up a audiovox dvd(pav1510dtv)
red ignition
yellow battery
black ground
d blue power antenna
pink parking brake(or ground)
speakers]
grey
grey black FR
white
white/black LF
Voliet
voilet/back RR
green
green/black LR
HOPE THATS HELPS
Jun 29, 2009 | Audiovox PAV-1510DTV Car DVD Player
Trying to install an in dash stereo can't figure out the speakers
depends on what wires you need the back of the raidio will have white grey green purple white is front left grey is fr green is back left and purple is back right if your lookin for truck colors get a manual or check to make sure there are no hots or grounds with a meter and twist one of the speakers ground up and with the hot touch each wire til u get sound idenitfiy the speaker wire to corect chanel
Feb 18, 2009 | 1995 Nissan Quest
Old pioneer GM120 amp
ok first the large red is battery connection, black large is ground find good source to ground, the 0.75 is most likely the power on for the amp you should hook it up to the power antenna wire on the radio. this will turn on the amp when the radio is turned on. the grey green and black are prob speaker hook ups input. the four wires are speaker outs, the red wire might be power for cd changer test it to see if it puts out power when amp is on.
Dec 18, 2007 | Pioneer GM-5000T Car Audio Amplifier
SUMAS Media SM-310T 3" Digital Wide Touch Screen Car Stereo DVD Logo
Top SUMAS Car Audio & Video Experts
xxxxxx xxx
Are you a SUMAS Car Audio and Video Expert? Answer questions, earn points and help others
