Question about Dryers
How do I reset my dryer - Dryers
Fisher paykel dryer resets repeatedly
this indicates it is getting too hot try running without vent attached if it runs ok it is a pluged or crushed vent
Nov 19, 2013 | Fisher and Paykel DEGX1 Electric Dryer
No power to dryer but have power at house...is there a reset button?
Check the circuit breaker in your housepanel. If it is tripped, resetting it will restore power BUT usually there is a reason for the breaker to trip. There may be an electrical problem with the dryer either an overload condition or a short circuit so check it's operation to be safe. If the breaker won't reset, unplug the dryer. If the breaker resets, then you have a problem in the dryer. if it still won't reset, then you have a problem in the wiring to the dryer outlet.
Nov 28, 2010 | Amana NDE2335AY Electric Dryer
Circuit breaker tripped, i reset it and the dryer read PF, cleared that...but now the dryer just beeps when youy hit any button like start. The dryer is a kenmore h3 gas dryer
try resetting the breakers again as they may have tripped again as sometimes they only move a bit and they look like they are ok but they are not.I would also unplug the dryer for thirty seconds to reset it and start again.
Oct 06, 2010 | Kenmore 82822 Electric Dryer
Manual reset keeps tripping. dryer may dry one
May sure your exhaust vent is not blocked or obstructed.
Jan 16, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I have an electric dryer. The breaker went off and when reset the dryer would not come back on. I am not sure if the push button on/off switch is now working or if there is a reset on the dryer
I have a Kenmore 80 series electric dryer. The light comes on when the door is open so I know it is getting power but dryer will not turn on. Is the push button not working or can I reset the dyer?
Dec 06, 2009 | Roper REX4634KQ Electric Dryer
Breaker was inadvertantly tripped by person which shut dryer off when reset breaker dryer wont work
You have to test the voltage to verify that the breaker did reset. Unplug the dryer, and verify that you have 240 volts at the receptacle
May 31, 2009 | Frigidaire GLER341A Electric Dryer
No heat in dryer and can't find reset button
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Neptune gas dryer beeps.
NO RESETS OTHER THAN TO UNPLUG THE DRYER FOR 5 MINUTES, THEN RECONNECT POWER. ON ANY ELECTRONIC CONTROL, THIS WILL RESET THE CONTROL'S MICROCOMPUTER. IF THAT DOESN'T SOLVE THE PROBLEM, THE TOUCH SWITCH MAY BE FAULTY.
Apr 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
