Question about Avanti Fitness AT480 Treadmill
Avanti at480 wont turn on error 7
On every boot it comes up with error 7 transmit error and the speed gauge flashes 68
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Avanti AT480 instruction manual
I will give some tips for user manual:
www.fitnessrepairparts.com you must pay
http://fitness.manualsonline.com ( this is free download)
http://manualsfactory.com
http://pdfservicemanual.com
sincerely
Posted on Nov 13, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a Avanti 380 when it is turned on LJE1 is displayed in the display and the number 68 flashes in the MPH display
adjust the REED switch, clean it, tight the connector very well.
see the diagram
2) replace battery, clean the contacts batteries, retight the springs contacts batteries, and clean it.
Proof again. try to RUN after you did the steps before, the software diagnostic, for troubleshooting, and fix it.
God bless you
Posted on Sep 06, 2012
Whytouchscreen wont accept instructions
All touchpad problems on the Avanti treadmills are related to the touchpad membrane assembly that needs to be replaced and it is a common fault!!
Jul 12, 2014 | Avanti Fitness AT480 Treadmill
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
I purchased an Avanti AT380 6 plus years ago. The bearings in the motor appear to be faulty and making a loud noise. The model is AT3800707090041 and bought at Workout world in Cannington. Has this got a...
The AT480 model has a 2 year warranty on the motor and 2 year warranty on everything else. It probably has the same warranty that you have on your AT380 machine. It can be fixed at your expense.
Jun 09, 2014 | Avanti Fitness AT480 Treadmill
That is the speed pot
Hi , the throttle pot , not the speed pot, that is the lever is fixed to, you push to go forward or backwards, please can you tell me the make and model of this scooter ?
Regards
Rob
www.gewizrepairs.co.uk
Feb 28, 2014 | Pride Health & Beauty
Avanti AT 380 gets an error code 68
556a61de-db92-4886-91ce-2e6c36b807f6.gifyou must LUBE the deck belt, front rollers and rear. This happen because the electronic system , shut down for to protect the system.
see the video and proceed according. See the diagram for REED switch clean it, test for open or faulty, tight the connector very well.
God bless you
Jun 16, 2013 | Avanti Fitness AT380 Treadmill
My avanti AT480 wont work. The console lights are on the safety key is on but when I press start nothing. I havnt used it for a long time. Do I need to reset but I cant find the reset button or something...
Unfortunately you may need a new console circuit board. I have just replaced 3 for the same treadmill model. It seems to be a slight problem with this model.
Feb 26, 2013 | Avanti Exercise & Fitness
Frigidaire affinity error code 68
what is the name and model of these dryer.rate these for clean solution
thanks
Jan 16, 2013 | Dryers
Avanti Fitness AT480 Treadmill Logo
109 people viewed this question
Top Avanti Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
Bill Boyd
Are you an Avanti Exercise and Fitnes Expert? Answer questions, earn points and help others
