Question about Jensen Phase Linear UV10
What audio jacks do I use to hook up my ps2 to a jensen uv 10
Does the Jensen UV 10 stereo have internal fuses that can be replaced
In the back of the set you should find a small 'spade' type fuse, replace with Fuse: 15-amp, mini ATM type
There is a fuse holder in on the yellow wire on the wiring harness, pull out the unit and replace fuse.
User manual: http://www.jensenmobile.com/docs/common/UV10/UV10_OM.pdf
Wiring diagram http://www.manualslib.com/manual/674477/Jensen-Uv10.html?page=4#manual
Good luck.
Jan 15, 2017 | Jensen Car Audio & Video
How do you connect a ps2 to the led24916dvdfhd
Well the LCD or TV must have rca..jacks yellow video..red and white is audio..if not u can get a component jack wires for PS2..red.blue..green...video....red and white audio..the TV must have those connections ..for PS2..or get old school cable connected hook ups for PS2..hooks in cable or antenna connecter on TV..UHF connected for ps2
Jul 21, 2014 | Video Game Consoles & Games
Screen is black but touch still wrks on jensen UV10
i really dont think you have the bypass connected right cause your still being blocked on your screen... re check your wiring maybe something connected wrong or bypass is defective...
radiorepair@windowtintingin239.com
Oct 28, 2013 | Audiovox Jensen Uv10 Dvd Video Bypass Hack...
How do i hook up my ipod to this deck?
U must buy an adaptor cable, to plug the audio and video to the RCA jack of ur Jensen.
U could ask the nearest dealer about the adaptor accessories, I have one myself!
Hope that plugs everything up!
Dec 03, 2010 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
Jan 27, 2009 | Jensen CD2610 CD Player
Can i hook up PS2 using only the white and yellow jacks?
i download and read your owner manual .
http://www.funai-corp.com/6pdf/om/DWT1304.pdf
i do see you only have a video and a mono sound input jack , so , your ps2 as in all RCA style jack inputs , yellow is video , red and white is audio , i will assume you have yellow plug in video and red or white in audio , and on your TV remote you hit the GAME button , i'm suprised they don't use the term VIDEO , but , anyway , are these the steps you have taken ?
Dec 30, 2008 | Durabrand DWT1304 13" TV
Can u hook ps2 to dual xdvd700
No you can not hook up a ps2 to the dual. It hads audio inputs but no video inputs
Oct 09, 2008 | Jensen VM9510 Car DVD Player
Connecting ps2 to my TV
did you hook the yellow up to a green jack labeld Y on the back? What kind of tv do you have? Some component inputs (the ones with the green Y jack) are not compatible with the video input you have, some are.
Jul 08, 2007 | Sony PlayStation 2 (PS2) Console
Help
No. The amplifier gets its signal from the RCAs connected to the "input" jacks, but the "output" jacks are just there to make it easier to add another amplifier. You only need to connect the inputs for the amp to work.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
Jensen Phase Linear UV10 Logo
46 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
