Question about Fisher Minute Mount Plow Fish Stik Fish Stick Contrlr
My fisher MInute mount 2 won't lower, It goes left and right and came up fine. Where should I start to rectify?
I haven't used it since season before last due to illness, just changed hydraulic oil and it raised beautifully.
2 Suggested Answers
tomcassidy84
  • 1585 Answers
SOURCE: Have new fisher minute mount 2 has no power no lights just stopped working like a blown fuse.
get engineer out don't mess ure g/tee up
Posted on Mar 02, 2015
I cant set the time on my adidas duramo watch. It says 'offset' and below it says '1H'
This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :-
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Aug 31, 2017 | Adidas Watches
I have a fisher minute mount 2 plow for some reason it only goes to the right now , not up or left , no matter what button I press on the control it goes right .
Start by plugging everything in and pop the cover off the control part on the plow and check for magnetism on all 3 solenoids when you hit the various buttons on your plow controller. The pull should be very strong and noticable...a weak magnetic pull is likely just residual magnetism on your screwdriver. In my case, the S3 solenoid wasn't firing and that causes exactly what you're describing.
If your S3 isn't firing you can test the wiring by moving the S3 hot wire to the S2 solenoid. If your wiring is good the plow will misbehave in an entirely different way. Also get out your ohm meter and test the S3, if its good you should get 7 ohms on it.
You need to use the guide from Fisher and be methodical about it. Start at the plow and work your way backwrds towards the truck.
Jan 27, 2016 | Cars & Trucks
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
My fisher minute mount 2 goes up slow but it turns left and right ok
You may have to release some tension in the packing nut on the piston seal, if its too tight it will bind and slow down the piston, try replacing the fluid also with synthetic Mobil 1 Transmission fluid !
Feb 17, 2015 | 2004 Ford F350
I have a fisher minute mount an older model with fixed controls. plow goes up and down but does not go left or right, sometimes with the control set for left or right it starts to go up ? where to sta
check the wiring connections on the plow solenoids to be sure they are correct, the second step is check the controller box, using a continuity check via multimeter set for DC voltage. I have an old western plow that had similar symptoms, and was the controller box.
Oct 19, 2014 | Cars & Trucks
Fisher minute mount plow
does the pressure release close to raise the plow?
Jan 05, 2014 | Dodge Cars & Trucks
Set time on adidas Adults' Performance Duramo Watch
Mar 15, 2012 | Adidas Watches
Fisher minute mount goes up and left and locks up
check your connections, especially the main power plug in, i have used a small "c" clamp over the connection to aid in the same problem
Oct 29, 2009 | 1998 Chevrolet C1500
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Fisher Minute Mount Plow Fish Stik Fish Stick Contrlr Logo
69 people viewed this question
Top Fisher Science & Laboratory Experts
J.D. Browning
J.D. Browning
ray gallant
Tom Chichester
Are you a Fisher Science and Laboratory Expert? Answer questions, earn points and help others
