Question about Apple 15-inch Retina Display MacBook Pro MC976LL/A 2.6 GHz Quad-co
Why is my finder so slow when deleting files. It lags for like a few seconds.
    Sergeant:
    Champion:
  • 242 Answers
Should be quicker than that!
DON"T defrag the hard drive, not a good idea with SSD. Is the bin empty or is it pushing deleted files into a full bin!
If the files are big, 20Mb P'shop files it will take longer.
Try a little jpg and make a note of how long it takes to delete different file sizes and different file types and in this was you might be able to narrow down the problem.
Patience is needed in tracking down the source of the problem.
Good luck
Posted on Nov 13, 2014
My computer keeps lagging and running really slow are there any solutions?
Hit on windows key + r and type temp when the temp window open delete all of the files then close the windows then again hit on windows key + r then type %temp% delete all of the files from that window. then gain hit on windows key + r then type msconfig then System configration utility will open the go to startup and uncheck unwanted software. we are not removing the software, we are removing only from the start up.
Sep 23, 2010 | Computers & Internet
Firefox is slow running
here is flawless solution to fix firefox problem: http://backspacetab.com/2011/05/17/firefox-lags-after-every-few-seconds/
Aug 16, 2010 | Mozilla Firefox
Unlock volume control
you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC Enable hidden folders. In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to music too loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
May 20, 2010 | Apple iPod nano
How to unlock volume limit
that is not a problem follow the steps below and if it doesnt work let me know i will assist you from there. unfortunately the password for the volume lock is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Nov 28, 2009 | Apple iPod nano
Is there anyway to resolve shutter lag on the Nikon Coolpix 8700?
oh what mode is your camera in? auto- adjust your Iso it is too bright or dark for your current setting
c1-(manual) change your f-stop and Iso. set the iso to 200 and move the F-stop to any number and test the speed.
c2-same as c1
If you need further clarification write back i'd love to help!
Jan 12, 2009 | Nikon Coolpix 8700 Digital Camera
I Can't unlock my Apple Ipod (black)
On MAC :
  1. Enable hidden folders.
    killall Finder
    killall Finder
  2. Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
  3. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds.
  4. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
On Windowsç
    In Windows Explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
  2. Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
Sep 18, 2008 | Apple iPod MP3 Player
Computer is extremely slow loading web pages
Welcome to FIXYA
Being slow to load webpages could mean you internet is slow or lag or it could be that you have to much cookies in your folders for the comuter to handle
first do this goto tools >intenet options>Browsing history > hit the delete key a menu will pop up hit delete all and should take a few min and it wil clear it up if not try a disk clean
try this for disk clean up
hit start bottom left of computer goto Accessories >system tools>disk clean this should take a few min then look on list and make sure all items on list are check and then hit delete it will as you if your sure hit contiune or yes and wait a few min might take longer if there is a lot of stuff in it that is junk
i hope this helps you out have a good day :)
Jul 15, 2008 | Computers & Internet
PSP running slow
I'm not sure if there is a VHS menu on normal firmware, but if your running custom most likely the problem is your last update. Here is how to fix:
Click Select->Select CPU Clock XMB->Toggle To Default->Exit Menu
Because your PSP is running on something like 20/10 and lagging real bad it may freeze when you open the menu, if so turn your PSP off by holding the power button up and forcing the shutdown, keep trying until you can get the menu working. It will also not respond to your commands properly, when you click down it will move through like 3 options because of the lag, be patient wait till it lands on CPU Clock XMB and follow the instructions. Happy Gaming!
Mar 11, 2008 | Sony PlayStation Portable (PSP) Console
Apple 15-inch Retina Display MacBook Pro MC976LL/A 2.6 GHz Quad-co Logo
69 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
