Question about Panasonic Kx-dt346 - 24 Button 6-line Backlit Lcd Display Telephone, White
How do I enable Caller ID on the KX-DT346 panasonic model? I cant seem to find the manuel, and we pay for it, I just dont know how to program it. HELP!
5 Suggested Answers
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Posted on Mar 24, 2008
freetek
  • 5568 Answers
SOURCE: Caller ID on the Panasonic KX-T7456 phone
Shouldn't be necessary; just make sure it has been activated.
Posted on Jan 29, 2009
SOURCE: Configuring caller IDfor India
use a caller id converter..i know u get it in sp road in bangalore
Posted on Oct 03, 2009
harshit_theg
  • 124 Answers
SOURCE: I am currently paying for Caller ID with phone company - how do I enable Caller ID on Panasonic KX-T7731 Phone
Please open this Pdf file and it will show you all the features that you can enable in your phone..
http://service.us.panasonic.com/OPERMANPDF/kxt7720.pdf
And in case of further enquiry you can contact me..
Posted on Feb 16, 2012
How will i activate the caller ID for panasonic kx-t7730 without installing caller id card
caller ID comes from your phone company and you normally have to pay extra for it
Sep 07, 2016 | Panasonic KX-T7730 Corded Phone
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
Feb 16, 2012 | Panasonic Lands Phones
How to active caller id for panasonic kx-t7730?
Caller-ID is a function of the phone SYSTEM and requires 3 things, CID service from the phone company, a CID card ending in 93, and programming. It works on TD, TA and higher models.
Carl
Nov 28, 2010 | Panasonic KX-T7730 Corded Phone
KX TG1061 panasonic phone called id not working in India
Try connecting your phone to some other phone lines in which the caller id is working properly and this way you can check if the problem is with your device or line.
For all the phones to display the caller information properly, CLID (caller line identification service) should be enabled for your landline connection. Please contact your phone line provider to enable this service and you should be able to see the caller id information in your panasonic device.
I hope this is helpful to you
thanks
Please rate the solution
Sep 18, 2010 | Panasonic KX-TG1033S Cordless Phone
Caller ID not functional in Model KX-TG-9331T and 9332T
Do you have the converter that converts your caller id to U.S. caller id?
Mar 15, 2010 | Panasonic KX-T7633 Corded Phone
Were those other instruments purchased in India? The problem is that the U.S .uses a different"signal" to send caller ID than India.
May 28, 2009 | Panasonic KX-TG9331T Cordless Phone
The id caller is not working in that cordless phone
Any Caller Id phone bought in USA will not show the id as the Caller id format in USA is FSK and in India it is DTMF. You need a caller id converter from DTMF to FSK. It is available online on www.ebay.in Just type DTMF to FSK converter and the item will be displayed. Right now it is avilable only with a seller in Bangalore and the price is Rs.589/- per piece. I bought it and it is working fine.
Aug 24, 2008 | Panasonic KX-TG1100 Cordless Phone
Panasonic KX-T2375MXW
Program , mute , 6 : now you can type the time
press program to store.
Mar 07, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic Kx-dt346 - 24 Button 6-line Backlit Lcd Display Telephone, White Logo
73 people viewed this question
Top Panasonic Radio Communications Experts
Jason
Lawrence Oravetz
Are you a Panasonic Radio Communication Expert? Answer questions, earn points and help others
