Question about Garmin GPSMAP 62ST GPS Receiver
My garmin 62st is very slow turning on, like it takes over a min to come on. Other than that it works fine once on. Please reply to. Kdbrowne@live.com. Thanks. Ken
Saeco Vienna deluxe is slow functioning post power on. 3 to 5 min. for the middle green light remain on. Press brew switch takes a 2-3 min. for the pump 2 activate. Once activated, coffee flows fine.
Machine is screaming for descaling. The Calcium deposits in the system are slowing down heating.
Do not think of using Vinegar.
Do not use R.O water or consider water is very soft in your area. There is nothing like that.
Dec 26, 2016 | Saeco Coffee Makers & Espresso Machines
Duracell batteries leaked in my Garmin 62st.. New batteries too..
You can take the bad batteries out and clean up the battery compartment, using isopropal alcohol (rubbing alcohol and a lot of q tips). . Problem is if the acid wrecked the contacts. Light corrosion (green,corroded copper color) needs to be removed with sand paper or emery cloth, until all the contacts are shinny metal again. maybe spray some silicon on the newly shinned metal to slow down re-corrosion. If the damage is serious, i.e. the metal is eaten away, then someone with soldering experience needs to desolder the bad metal and resolder in good. This can be quite expensive is you take it to a technician.
Feb 23, 2015 | Garmin Gpsmap 62st Handheld Outdoor Gps...
USERS MANUAL GPS
You may download the 62st manual and more here.
Dec 31, 2011 | Garmin GPS
MANUAL FOR GPS
You may download a free copy of the manual and more here.
Dec 31, 2011 | Garmin GPSMAP 62ST 27 in Handheld GPS...
My garmin device cant locate satellite,and its pretty slow.
Make sure that you have the unit fully charged and also in line of sight, turn it on and leave it for upto 5 mins without moving it lean it against a window, if this works then there is not a problem with the unit.
Dec 06, 2010 | Garmin nuvi 250W GPS Receiver
Water output too slow
Try to see how long takes whout coffee. If it is ok then the coffee is too fine or wed or the filter inside the holder need cleaning remove filter and wash it with hot water and brush so all holes to be open.
If after this you still have slow water without coffee the the pressure pump is not working properly and it need ither descaling or is complete damage so you need a new pump. Good luck.
Please remember to vote for this answer thanks
Feb 14, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Trying to register new Garmin nuvi 750 and can't get pat sign on
Perhaps if you can reply with your unit's internal serial number we can confirm if your using the correct serial number to register. Please turn the unit on and go to the Tools at the bottom, then touch Settings, then System. Here you can touch About at the bottom and recall your Unit ID
Dec 15, 2008 | Garmin nuvi 750 GPS Receiver
I just bought a garmin 260w and im wondering if there is any updates that i need to put on it
Normally with a new device you should not need to udpate it as long as the normal areas where you go to are there and the unit works fine. However if you need further maps and such you may click on the link below. ( I assumed you are in the US If not kindly reply back)
http://www8.garmin.com/support/download.jsp
I hope this has answered your question sufficiently. If you have more questions please post a reply. Thanks.
Oct 05, 2008 | Garmin GPS
Garmin GPSMAP 62ST GPS Receiver Logo
44 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
