Question about Radio Communications
Help...Extremely high swrs. Galaxy dx 44v twin
Help...Extremely high swrs. Galaxy dx 44v twin tdin Wilson 2000 antenna's, custom new rg59 coax. Mounted on a 99 Kenworth W900L. Swr is near set mark. Good continuity, radio just back from shop for peak and tune.
    Master:
  • 742 Answers
Measure out your coax in 3ft intervals. Like if you need 7ft use a 9ft length of coax. Also make sure your mirrors are grounded use a external swr meter as well, the internal swr on the galaxy could be off. .
Posted on Nov 15, 2014
New galaxy dx98vhp, new coax, new wilson5000, new
check that there is a ground connection at the antenna, and that the antenna is not near anything conductive. If your swr is 1.8:1 or lower, your good to go
Sep 07, 2014 | Radio Communications
Low pwr on xmit,weak rec,swr alert lite on xmit swr 1:4-1 on ch 20
you have no power because your radio is not tuned to your antenna.You get a new radio and put junky coax and a decent antenna and you expect it to work right. Get 75 ft of rg-213 and you will see a change.
Jan 08, 2013 | Galaxy Radios DX-2547 40-Channels Base CB...
Self adjusting SWR does not work on 959 Galaxy
the swr on the radio is not what you are thinking it is. You have to set the SWR to anything below a 2.0 and the meter will let you know when and if your swr gets to high.
Sep 23, 2012 | Galaxy Radios DX-959 CB Mob Auto Swr...
CAN THE LEGNTH OF THE COAX COUSE THE SWR TO BE HIGH
you should use no more than 18 ft. of coaxhave a tuneable antenna.check your match on the antenna to see if its less than 2.5:1
Jun 10, 2012 | Galaxy Radios DX-929 40-Channels Base CB...
I have a cobra 29 ltd the red antenna light was coming on replaced the coax with 18' coax have Wilson 2000 antenna calibrated radio red light still coming on and and swrs not staying consistent when...
Best way to locate the problem is connect the radio to a Dummy load known to be good====if swr still comes on it is in the radio--if not in the antenna system.
Apr 28, 2012 | Cobra Radio Communications
How do I tune my Galaxy DX 55v cb?Im getting out and people say they hear me clearly but I cant pull nobody in.I need help setting my knobs where they need to be.The cb used to be
Get or have someone Set the SWR's on your antenna.That is the first thing you should always do before even talking on the radio.. Check the antenna.
You will need an SWR meter to check your antenna. FIRST.
I would find help at a local cb shop.. They SHOULDN"T CHARGE to help you SET the swr. only if you need a part or something ..
I don't charge to SET SWR"s .. only if the cust needs a insulating washer or another antenna, or new coax, so-239 etc... I would be glad to help you.. let me know if we can -- CB Shop Temple, TX
Nov 27, 2011 | Galaxy Radios DX-55V Base CB Radio
I have a galaxy 44v it transmits on fm but receives on am what can i do to fix this problem
Replace the AM final, then make sure your antenna is tuned to lowest SWR to prevent the final from burning out again.
Nov 24, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
Quiet Galaxy DX 44V
Sounds like you have lost a final or a driver transistor if so a shop or reputable repairman is your best answer. You should also have him check your cables and SWR on your antenna system as well as check for loose grounds. Sounds like you had a high SWR and blew out a final transistor. But it could be as simple as a loose component or cold solder joint in the radio. Get professional help.
Jul 28, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
Can't talk about 2 miles ,swr is good
If your talking at least 2 then it sounds like it is the antenna. Any antenna should talk 10-12 miles on a good day, no matter what radio you're using. So I'd get a second look at that system.
May 30, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Tx problems on a dx 98 vhp can,t check a swr the radio is in a freightliner classic 2003 I changed the co phased coax and my antennas are two wilson 2000 mirror mounted ...
Hi and welcome to FixYa,
Initially, determine if the needle will deflect signifying power output when switch to PWR:
  • if yes, then check continuity of coaxial cable as well as grounding of antenna mounts;
  • if no, then the finals and driver would require further looking into (8 X IRF520).
Additionally, check the 2 30Amps fuses
Good luck and thank you for asking FixYa.
Dec 19, 2009 | Radio Communications
Radio Communications Logo
120 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
