Why do I blow fuses? - Audio Players & Recorders
  • 694 Answers
Hi Pete
Are you blowing fuses in the receiver/amp or speakers? Without knowing what device you're referring to, I would guess that you have a problem with your speakers not having enough power handling capability for the amp that's driving them (which would blow your speaker fuse) OR (if you're blowing receiver/amp fuses) too many speakers wired in parallel showing your receiver/amp far less than the 8 ohms or even 4 ohms impedance that it is rated for. For example, two four-ohm speakers wired in parallel shows a 2-ohm load to the receiver/amp. Not many consumer devices have the capability to load down to 2 ohms.
Hope this helps.
Posted on Nov 13, 2014
  • 1 more comment
  • pete
    pete Nov 13, 2014
    I'm blowing a fuse on a JVC subwoofer Model SP-PWA 582.
  • pete
    pete Nov 13, 2014
    The fuse blows as soon as I pull the subwoofer into the power outlet.
  • Steve
    Steve Nov 14, 2014
    Then I would have to guess that somehow either the input has been overdriven and cooked your transformer or the speaker itself has been overdriven and caused a dead short in the speaker coil. A trip to a repair facility is ypur best bet. Sorry Man.
I have a 2004 Pontiac Grand it keeps blow the ignition fuse now my dash and brake fuses blow! I use atuo door lock blows a fuse where do I start??
Remove the fuses to the circuits that blow. Then one at a time, install a fuse, turn any component on and see if it blows the fuse. Have you had an accident recently ? If so, maybe a wiring harness has been damaged and causing your problem.
Nov 27, 2016 | Pontiac Cars & Trucks
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
Pioneer 74txvi fuses (fast or slow) burning
If there is nothing left inside the little glass tube, it's a fast blow. A slow blow fuse will usually have a spring and some other material that make up the slow blow mechanism. slow blow fuses used to also have 'SB' stamped on the metal end caps. The fuse holder may also tell you. If you cant figure it out, put in a fast blow and see how long it lasts, If if blows when you turn the volume high, you should try a slow blow.
Jan 22, 2015 | Pioneer Audio Players & Recorders
Could a 1000 amp battery blow fuses in a 1999 blazer
Likely there is a blown fuse but a battery won't blow a fuse on its own. Change any blown fuses and if that fixes the issue and the fuse doesn't blow for awhile then your ok but if the fuse blows quickly then you have an issue with the electrical system and you need to take it to a shop
Apr 17, 2014 | 1999 Chevrolet Blazer
Can i use another 4a 250v fuse for my cerwin vega LS12 if its not a (slow blow) ,and what would be the outcome
Fuses have different blow characteristics. Such to protect components differently. An extremely fast fuse would protect sensitive components like tweeters and slower fuse will allow transcients to pass and blow on long time fault. If you put a slow blow in place of fast blow, it won't blow as quickly, but it could allow the protected device to be damaged. In reverse, you put a fast blow in place of slow blow, it will blow at normal transcients and be a nuscience to always replace.
You can cross to a fuse of different manufacturer. The reliable manufacturers will have detailed datasheet and subsitute or similar fuse to the fuse you are looking for.
Oct 23, 2013 | Cerwin Vega LS-12 Speaker
Hi, I own a 96' 4x4 3.4L Ext. Cab T-100 and it WILL NOT STOP BLOWING THE EFI FUSE! Before, it seemed as though the fuse blow time to drive ratio got smaller as the engine got hotter. In otherwords it...
possibly you have a schafted wire in the wiring loom at the fuel injectors, or at the fuse junction box. (short) hit a bump just right and it shorts out blowing the fuse.
Feb 12, 2011 | 1996 Toyota T100
Four Wheel drive not working. Blows fuses.
Hi:
Your four wheel drive push button system has only 3 components, so there is a way to narrow down what is blowing the fuse:
the system includes the push button panel and indicator light, the shift control module, and the shift control motor.
The shift control motor is the only part that can draw enough current to blow the fuse. If for some reason the transfer case is jambed up, that could blow the fuse too...So if you are planning on attempting repair yourself:
first, unplug the connector off of the shift control motor, and see if the fuse still blows.. if not, then remove the shift control motor from the side of the transfer case and plug it back in to the harness and see if the fuse blows. If so, then the shift control motor is bad, if the fuse doesnt blow then you need to check out your transfer case.
Dec 08, 2009 | 2000 Chevrolet Blazer
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
PC power supply fuse - T6.3h 250v engraved on end
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
Apr 02, 2009 | Dell Computers & Internet
91 people viewed this question
 Grubhead
Grubhead
