Question about Nespresso Aeroccino Automatic Milk Frother
How do I change the fuse?
The Aerocchino came with the "Little Pixie" Nespresso
Just changed the Pixie Nespresso plates - now when using machine have a red light flashing. What is wrong?
i like to halpe but what is the foult and model try removeing the plate and put the old one back see what happens . there may be a sonsor ?
Aug 31, 2017 | Nespresso Coffee Makers & Espresso...
I need to buy a T2/2 >ABS< part for my Nespresso machine, where do I get it?
visit this site for spare parts: https://www.nespresso.com/.../machine-spare-part-pixie-drip-tray-capsule
Dec 06, 2016 | Nespresso Coffee Makers & Espresso...
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
How do I repair a Teflon tube on NESPRESSO Pixie COFFE MACHINE
You purchase the correct tube as a spare part from a supplier. Give your model to Nespresso and ask for direction.
Dec 20, 2014 | Frontgate Nespresso Pixie Brown Machine -...
Why won't my Nespresso Pixie red low water indicator light go on when tank is near empty?
merely out of curiosity is the light or lights bad? If there's a separate red light you'd need to take it out and use an inexpensive voltmeter to see if it's getting a signal.
Either that or look at it closely next to a light. If you see a bad filament then the bulb needs replacing.
Nov 27, 2017 | Nespresso Pixie D60-US-AL-NE Aluminum...
Nespresso pixie c60 cup stuck
Can't make the coffee and can't open the lever of pixie nespresso machine
Feb 10, 2013 | Nespresso C60 Pixie Electric Titan Single...
I want to know if my Nespresso Pixie D60 has a fuse protection because i plugged my 120 volt 60hz machine into a 220 volt 50 hz power supply without a converter.has my nespresso completely burnt and ruined...
There is not a fuse for protection from this insitent. However the damage on your machine is deoent from how long you left it on with 220v. It can be damage full but it can also not hapent anything. Have you check it again with 120V, since there is a chance that it can still work normal but in any case if not working you may need only a small repair by an eperience percon.
Sep 23, 2012 | Frontgate Nespresso Pixie Brown Machine -...
Nespresso Aeroccino Automatic Milk Frother Logo
759 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
