Question about Microwave Ovens
I have a samsung microwave model # smh1816s working fine all of sudden stop working no power is there a fuze if so where
Microwave only been in service for a year and was working fine...all of a sudden it stopped working no power at all was wondering if a fuze blew??
    Prodigy:
    An expert who has answered 500 questions.
  • Microwave Ovens Expert
  • 650 Answers
They do have a fuse. They also have thermal cutoffs and possibly a thermal flame sensor fuse. the main fuse would be near the control panel the thermal flame sensor is usually near the back of the cavity usually on the left side on the outside of the cavity.
Posted on Nov 15, 2014
  • rich
    rich Nov 15, 2014
    Thank u for the info I will start there
MicrowaveSvc
  • 9047 Answers
SOURCE: LG Microwave LMVM2055ST Just stopped working!
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics. You'll probably have to call them.
Posted on Dec 13, 2008
  • 17 Answers
SOURCE: GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
Posted on May 17, 2008
SOURCE: My microwave has stopped working and switched on suddenly!!
My Sharp microwave oven touchpad stopped working. It's about 3 years old. Is there any way to get it working again?
Posted on May 25, 2008
  • 4 Answers
SOURCE: Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Posted on Apr 03, 2009
  • 574 Answers
SOURCE: 1 yr old Oster 0.7 CuFt Microwave Model OM0701A stopped working
could be door interlock switches, door misalignment
Posted on Aug 29, 2009
If water blew up in microwave will it damage the microwave
if the display and the lights are out after the water/steam explosion then yes id say it did have an adverse effect to the operation of the machine , there are no user servicable parts inside a microwave so dont open the case your self , these little boxes contain enough power to light a house up ,even with it unplugged from mains power
Jan 10, 2015 | Rival MT660 Microwave Oven
Glmv169gsb stopped working
You blew the fuse on the control board. Unplug it, remove the cover to expose the guts, and you should see a fuse. Replace it and try again. If it blows again, then you will likely find it cheaper to get a new microwave than have the control board replaced.
Nov 13, 2013 | Frigidaire GLMV169D Microwave Oven
Microwave appears to have no power. Display is blank. Checked and found internal fuze blown. Replace the fuze with 20A ceramic fuze. Display works. When try to cook something, microwave runs for about half...
You have a short somewhere. Possible causes, defective interlock switches for the door,shorted capacitor, shorted diode, defective triac. More than likely its one of these.
Oct 01, 2009 | GE Monogram ZE1660SA Microwave Oven
Stopped working completely
No, your fuse has blown due to an electrical problem. Ill get right to it. Very possibly the capacitor and HV diode need replacement.90% of the time this occurs. If by chance it still doesn't heat or still blows fuses, replace the magnetron. Before you do all this, look carefully at the transformer and look for any indication of burning, or flashing having taken place. If so, replace the transformer first.(Transformer doesnt often go faulty).
Sep 27, 2009 | Maytag MMV4205 Microwave Oven
No Power - Emerson MW8773SL Microwave
LOOKK FOR FUSE UNDER SCREWED IN PANEL!
Dec 10, 2008 | Emerson MW8775W Microwave Oven
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
No power
A microwave should be plugged into an outlet that is on a separate circuit. Make sure you didn't trip a breaker that serves this purpose. If all is well, then take your oven to an authorized servicer in your area. DO NOT attempt to let anyone but an authorized servicer to even touch it. Shock hazard with severe injury could occur.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
Sounds just like a bad door switch or door switch mount. Probably the upper one. Safety info, disassembly tips, and door switch test and replacement info are all available at our Web site. See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
398 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
