Question about Texas Instruments TI-Nspire CX CAS Handheld Color Graphing Calculator with Computer Algebra System
My TI-nspire CX CAS just got a white screen with a black stripe.
I tried various things such as reset commands (doc+enter+ee, things like that), and unplugged the battery a couple of times. Still no luck. The black stripe is down the middle, slightly to the right, and sometimes the left side of the screen turns black and flashes.
  • Texas Instru... Master
  • 7,993 Answers
Unplug the battery? I thought that the battery was built in.
Posted on Dec 05, 2014
  • 7993 Answers
SOURCE: My TI-nspire CAS doesn't want to go on! I changed
Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Posted on Oct 18, 2009
  • 7993 Answers
SOURCE: I have a TI-nspire CAS
You should ( a suggestion) reset the OS by pressing the button on the back of the unit.
If that does not work, you may consider reinstalling the OS. The procedure as described in the TI Knowledge Base is as follows.
What steps are required to reinstall the TI-Nspire family operating system?
To reload the device’s OS using a computer with TI-Nspire Computer Link:
• Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable.
• Open the TI-Nspire Computer Link software. The select device dialog should appear, and detect the device.
• Either drag the OS file (available in the ‘downloads’ area at education.ti.com) onto the TI-Nspire File Browser portion of the window, or click Tools -> Install OS.
To reload the device’s OS using another TI-Nspire or TI-Nspire CAS device:
• Connect the two devices using the USB Mini A to Mini B cable. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
• On the sending unit, access the document chooser by pressing [Home] [7]. Once in the document chooser, press [Menu] and choose 9:Send OS…
NOTE: Users can only send an OS to a unit of the same model. Users cannot send an OS from a TI-Nspire to a TI-Nspire CAS.
Please see the TI-Nspire guidebooks for additional information.
Hope that helps.
Posted on Oct 28, 2009
  • 7993 Answers
SOURCE: TI NSPIRE CAS WONT LOAD
Try the reset procedure. There is a reset button on the back of the calculator. Use a straightened paper clip.
Posted on Feb 01, 2010
SOURCE: My TI-83 just froze and I can't get it to even
Take out the batteries. Then power it on. And now 2nd > +, 7, 2
Posted on Mar 14, 2010
  • 12 Answers
SOURCE: I downgraded my TI-Nspire's OS
I had this same problem myself and I had to look everywhere to find a solution. You will have to remove the current OS from your device. Heres how.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=101985&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGC81E19298A9321E38D51491551F331C8CCDA6801E50CC672F84B3EFDF0F6ACEF9DD42026E6C2FF1F9579670CF87CEAF79D
I couldnt use option 2 for some reason and had to use option 4 (complete format, luckily I had backed the files up earlier) but once it was reformatted the device showed up in the software and told me to update the OS. From here you just install the latest OS as you would normally.
The problem with what you and I did is that previous OS versions (1.7 in my case) dont support the keypad, you may be able to use the older version with a different keypad but I'm not sure.
Anyway, I hope you can fix it, good luck.
Posted on Jan 08, 2011
The three lights across the top stay **** and shows no time and can't do anything else
Try unplugging the alarm clock and removing the 9v backup battery. Let it sit for about 60 seconds. Reinstall the battery, plug in and reset the time.
Mar 30, 2014 | Sonic Alert SBB500SS Sonic Bomb Alarm...
My TI NSPIRE CX CAS is stuck at the loading screen - it keeps loading and then going back and repeating (only when plugged in). I have tried resetting it whilst holding down EE, doc and enter. When I do...
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and
the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
• While holding these keys press [on].
Please Note: For TI-Nspire Family handheld units that
contain rechargeable batteries you can alternatively hold the above
keys while pressing the [reset] button on the back of the handheld rather than
removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu
with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit
restarts.
• 2: Delete Operating System - The operating system will be deleted
without deleting any documents on the system.
• 3: Delete Document Folder
Contents - This will delete the user's documents, but will not delete the OS.
Selecting this option is the same as using the RESET hole on the back of the
unit.
• 4: Complete Format - This will delete the OS and all documents for a
total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled.
Oct 09, 2013 | Texas Instruments TI-Nspire CX CAS...
On the temp display it is flashing EE. Any thoughts on what I should do?
unplug unit wait a few secounds then plug it back in and try it may reset.
Aug 06, 2013 | Haier Dd400rs Refrigerator
My monitor on a macintosh Gf is black since setting the resolution toohigh. What can I type in or do to get the resolution to decrease even though I cannot ee the scren as it is black? Thanks, Rochelle...
You could try resetting the PRAM which resets various things to default status. You do this by holding down the following 4 keys together "cmd" "option" "P" "R" at the startup sound, keep them held down until it restarts and keep holding them down until you hear the startup sound 2 more times and then let go.
If that does not work try booting up in safe mode by holding down the shift key at startup and then when it boots up change the resolution to one that works and then restart.
Hope this helps.
Jan 27, 2012 | Apple iMac G4 Desktop
My Sony Dream Machine won't save the correct time. When I set the date, it defaults back to 2009, and even when I get the correct time set, the clock won't advance. It's been 8:52 PM for...
My wife's unit has the same issue - tried the firmware update (from Sony's website) and their suggested fix with no luck. Still works as a digital picture frame, but wrong date and stuck time kind of disappoint.
FYI - Suggested fix for stuck date/time:
Unplug unit.
Remove backup battery.
Leave for 30 seconds.
Plug back in and then put battery back.
Set date and time.
Didn't work for me, but maybe you'll have better luck.
Sep 07, 2011 | Sony Dream Machine FMAM radio with...
I have a Ti nspire and its running slow. I would like to erase all my old data and start fresh. how do i do this
First remove the batteries, then replace them. After doing this, if you have the touchpad version, press Doc, EE, Enter, and On at the same time. From the maintenance menu you then click reset. Or you could hit the button on the back of the calculator, whichever works for you.
Feb 15, 2011 | Texas Instruments TI-Nspire Graphic...
What does the ee symbol above the qoutation mark mean
What you call a quotation mark is in fact a comma. It is used to separate arguments inside commands that require more than one arguments, or the elements of a list.
The [EE] that you access by pressing [2nd][comma] is very useful in scientific areas of studies such as physics and chemistry. It is a shortcut for times 10 to a power.
If you want to enter Avogadro's number you enter
6.02[2nd][EE]23 [ENTER]
The electon charge is
1.6[2nd][EE] (-)19 [ENTER] . Here the (-) is the change sign key located between [.] and [ENTER]
The [2nd][EE] sequence must always be followed by an exponent even if exponent is 0.
Try these
[2nd][EE] 0 [ENTER] (Surprised? You should'nt be!)
[2nd][EE] 1 [ENTER]
[2nd][EE] (-) 3 [ENTER]
Hope it helps.
Nov 04, 2009 | Texas Instruments TI-83 Plus Calculator
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Hi Guys, I have a Dell Insperion Laptop--one of the really older basic models however it has been giving me great service for several years, I am very careful to do my disk clean up & defrags regularly. I...
A couple of things to try: Take out the battery and try to turn on the laptop while it is plugged in with out the battery.
Unplug the laptop and try to turn it on with just the battery.
Leave the laptop plugged in for a bit and then try to start it up.
Are any of the lights on the laptop on?  Also, the battery should have a status light on it as well.  Check what that says.
Dec 31, 2008 | Computers & Internet
Texas Instruments TI-Nspire CX CAS Handheld Color Graphing Calculator with Computer Algebra System Logo
807 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
