TV Model: Panasonic Viera 50" TC - P50UT50 I just replaced my sustain board "TXNSS1SDUU SS BOARD" which I'm hoping fixed my 8 blinks problem. However, now when I power on the TV I'm getting a 7 blinks issue. Any help or assistance would be appreciated.
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Posted on Nov 13, 2014
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: no picture and power light blinks 7 times on my viera tc-p50st30 plasma tv when it is turned on
That can be caused by either the SC or SD board. Contact the people at www.tvrepairworld.com they can assist with proper diagnosis and they also should have the replacement board
Posted on Jun 02, 2012
bugoy31
  • 1238 Answers
SOURCE: i have replaced the p board and sc boards in this panasonic tc-p50s30 viera tv and still have the 7 red blinks? what else can be wrong?
7 blinks is indicate for faulty power supply however if you already replace it the possible problem is on main board..
Posted on Jun 07, 2012
SD Tech
  • 14553 Answers
SOURCE: Panasonic TC-P42C2 Horizontal Lines in Picture
problem could also be inside the display panel.
Posted on Jun 08, 2012
gopakumarg43
  • 74136 Answers
SOURCE: I need help changed power supply board and ss board and still no picture it is a model TC-42PX14 panasonic the red light still blinks seven times. At wit s end isn't much, can you help me.t
Check this link and select the site named 'Electro-help' You can get more details about the fault to your TV, with 7 blinks of standby light. Check this link and select the site named above.
Posted on Jul 28, 2012
My panasonic plasma started showing vertical lines
Look at the buffer board or the Y sustain board on a plasma having picture aberrations.
Sep 16, 2016 | Panasonic Viera 50" Class 1080p Full HD 3D...
How do I fix my Panasonic Plasma TV?
Call in a repair specialist. You have done everything you can do.
Nov 18, 2015 | Panasonic Viera TC-P50S2 50" Plasma TV
Only the right side of my Panasonic Plasma TV (TC-P50UT50) is displaying. The left is is black with some white flickering lights. Sound and video on the right side are perfect.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 01, 2015 | Panasonic Viera 50" Class 1080p Full HD 3D...
Panasonic tv stopped working, red LED blinks, how do I fix it. My TV model is TC-P50UT50 T
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name and type of your device, in the search box [at the top right] of the display window. It will make surf easy.
Jun 15, 2015 | Panasonic Viera 50" Class 1080p Full HD 3D...
Electronic diagram
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/. Blinking codes and troubleshooting procedure to Panasonic Plasma TVs, are given.
Jan 10, 2014 | Panasonic Viera Tc-p50ut50 Hd 50 1080p...
Viera tc-p50ut50 light blinking eight times
One the circuits popped. you can locate the bad board and replace. Use these charts to help locate the problem.
Apr 11, 2013 | Panasonic TCP50UT50 Smart Viera 50 Class...
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Electro Med Services...
