Question about Vehicle Parts & Accessories
Car jack can refill it
Refill jack
  • 41 Answers
If there is a plug on the cylinder that is where you add oil
Posted on Nov 13, 2014
How do I refill my MVP SuperLift 2 ton floor Jack?
hydraulic jack oil. or like me use regular transmission fluid
Sep 16, 2014 | Cars & Trucks
I also have a Michelin 3 1/2 ton jack that will jack up. My guess is that it needs hydraulic fluid but I have no idea where to fill it with fluid. Where do I refill the fluid at on this jack?
MOST JACKS HAVE A BOLT LOOK PLUG TO REFILL THE JACK AND YOU DO IT WITH THE JACK AT THE LOWERS POINT, SOME HAVE A RUBBER PLUG. YOU CAN USE P/S FLUID OR TRANMISSION FLUID TOO TO REFILL IT.
May 24, 2014 | Cars & Trucks
Where is the transmission fluid refill
There is a plug on the transmission where you add the fluid. Its in a tough spot and you'll probably have to jack up the car to get to it from the bottom side.
Apr 15, 2014 | 1997 Plymouth Neon
Clutch oil reservoir
refilling is a good idea-but you need to find where its leaking at-be carefull if you jack it up-always use jack stands -cheers Denny
Nov 30, 2013 | 2002 Mini Cooper
Transmission/97/toyota/camery
Refill as fluid level drops as torque converter refills.
Jun 12, 2017 | 1997 Toyota Camry
Transmission nocks in 5th gear
Bent synchonizer ring. Contrary to what some may tell you, do not park a manual transmission vehicle IN GEAR. This is even worse, if you park on a hill. If the emergency brake is not set to take the weight (force) first, then the gear synchonizer rings can be bent causing shifting and noise problems later. Set the parking (emergency) brake first, shift into Neutral taking your foot off the brake pedal to let the emergency brake take the weight, shut off the engine and then shift in to gear if you want to leave it IN GEAR when parked. Try draining your Manual Transmission oil and replace with either a top quality Hypoid Gear Oil AND Slik 50 Gear Oil Additive or simply use Castrol TAF-X Gear Oil. Remember to clean the magnetic drain (sump) bolt as they are usually covered with fine metal filings. A tooth pick works great on the edges of the magnet. A short piece of clear tubing 3/8 inch diameter will make the refill job easier when fitted securely to the nozzle end of a gear oil container. Place the vehicle on level ground and FIRST remove the square refill bolt with a ratchet (if punched inwards) or spanner (if outwards). THEN, drain the transmission oil. Some sumps (drain plugs) use a regular bolt and others a square hole that you can use a ratchet with suitable size adapter. Many are 1/2 inch square, so if you have a 3/8 in ratchet you need to get a 1/2 inch adapter for it to open the drain plug before you start. If you can't physically slide under the car, you need to place it on JACK STANDS or better still, a Hydraulic Lift. Following the manufacturer's instructions for jacking your vehicle and placing JACK STANDS. Note: As an extra precaution consider keeping the car jack raised to the same height as the JACK STAND on the side of the vehicle that you will be crawling under just in case something slips. It doesn't take any more time as you will still need to jack the car up a bit to remove the first jack stand and then begin the lowering process one axle at a time after you're done.
Sep 25, 2012 | 1985 Nissan King Cab
How can i remove the rear shock from coilspring without jaguar tool
Go to your local auto parts store and ask for a mobile spring compressor
Mar 10, 2011 | Jaguar XJ6 Cars & Trucks
How to bleed brakes on 1500 1999 silverado I lost brakes completely but there was still one-half in reservoir, replaced some brake lines, having hard time bleeding
In order to do this. Jack up the car on tire at a time. Look underneath the car and you should see a bleeder valve. Attach a hose to the valve, then run the valve into a jar filled with brake fluid. Have some apply pressure to the brake pedal. Open the valve insuring the hose is in the brake fluid. Do Each wheel on wheel at a time. Refill the brake resivor each time After bleeindg all brakes refill resivor. .
Nov 29, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Hi, i lift my lincoln mark viii '94 to change the breaks. and when a removed the jack lifter the suspension came down (back and front). what happenned??? what can i do? thanks.
If you failed to shut off the air suspension switch (located in the trunk) you may have blown an air line when you jacked the car up. All Lincolns equipped with air suspension should have it shut off whenever jacking up the car. You can try to turn the switch off and back on to see if the air springs refill but if not, trace the air lines from the compressor to both the front and rear to check for a blown line. If you don't detect a blown line, you may have damaged the air springs.
Nov 09, 2009 | 1994 Lincoln Mark VIII
Suzuki Verona 05- where do I refill the transmission fluid?
The 04 to 06 verona does not have a transmission dipstick, it is filled with a life time transmission fluid and thus does not need to be filled. If you have leaks and are concerned about the level there is a fill plug. BEWARE these transmissions do no use off the shelf ATF, Check with suzuki for the correct fluid and be sure to bring your checkbook
Jul 29, 2009 | 2004 Suzuki Verona
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
