The Chaintech 7VIF4 Socket A microATX Motherboard is loaded with advanced features and cutting-edge technology, providing enthusiasts who demand blistering performance a complete digital media experience. This board contains the VIA KM400 chipset for optimal system efficiency. The 7VIF4 with VIA KM400, WOL, WOR, Audio Support, IrDA, LAN, AGP, and USB creates the foundation for one of the fastest PCs ever designed.The Chaintech 7VIF4 Socket A microATX Motherboard is loaded with advanced features and cutting-edge technology, providing enthusiasts who demand blistering performance a complete digital media experience. This board contains the VIA KM400 chipset for optimal system efficiency. The 7VIF4 with VIA KM400, WOL, WOR, Audio Support, IrDA, LAN, AGP, and USB creates the foundation for one of the fastest PCs ever designed.
Motherboard Specifications Processor Interface Socket A Form Factor Micro ATX Processors Supported AMD Athlon up to 2000+ @ 200 MHz FSB AMD Athlon XP up to 3000+ @ 333MHz FSB AMD Duron up to 1.4GHz @ 200MHz FSB Front Side Bus 200MHz 266MHz 333MHz Chipset Northbridge VIA KM400 Southbridge VIA VT8235 Memory Memory Supported PC1600/2100/2700 DDR Number of Pins 184-Pin Maximum Memory Supported 2GB Number of Slots 2Motherboard Specifications Processor Interface Socket A Form Factor Micro ATX Processors Supported AMD Athlon up to 2000+ @ 200 MHz FSB AMD Athlon XP up to 3000+ @ 333MHz FSB AMD Duron up to 1.4GHz @ 200MHz FSB Front Side Bus 200MHz 266MHz 333MHz Chipset Northbridge VIA KM400 Southbridge VIA VT8235 Memory Memory Supported PC1600/2100/2700 DDR Number of Pins 184-Pin Maximum Memory Supported 2GB Number of Slots 2
You can't post conmments that contain an email address.
There is no AMD Athlon that runs natively at 2.5 GHz. They were badged on comparative rating: a 2500+ will run at 1833 MHz or 1867 MHz, depending on the version.
If your hard drive is NOT a SATA hard drive, try looking on the back side of the hard drive, and see if the jumper pins are set at "cable select". If they are not, this could be the problem. Once the pins are configured correctly, this should solve the problem.
