Question about Refrigerators
I replaced the interior light switch and still have no light
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
The bulb or socket could be bad. I have ran into some light bulbs that have so little solder on the center post that it won't make contact on the receptacle.
Posted on Nov 15, 2014
  • John Clayton Nov 16, 2014
    I did raise nthe lower contact on both sockets and bingo.Thanks
  • Ty Roshdy Nov 16, 2014
    cool glad I could help.
2005 X-Trail interior lighting diagram
If you open other doors besides the driver door do the lights work? If so the door ajar switch is defective in the driver door. Also can you turn on the interior lights from the headlight switch control?
Jul 09, 2016 | 2005 Nissan X-Trail 2.0
My interior lights do not shut off, why?
Do you the headlight switch pushed in. That will keep interior lights on. The switch that turns the interior lights off is on the inside door jamb. Push it is and the lights should go out, of they do not it is broken and needs replaced.
Mar 11, 2015 | 1995 Mercury Grand Marquis
Interior lights flash and door ajar light on
sounds like the door ajar switches are sticking check doors one at a time to see which switch is doing it remove switch check wire behind switch if thats ok replace switch
Apr 16, 2014 | Vehicle Parts & Accessories
1996 jeep grand cherokee no automatic interior lights
1. If you have the light switch in the wrong mode the lights will not operate when you open the door.
2. If the interior lights do not operate at all (ie you cannot switch them on and off manually)then you need to check the fuse for the interior lights.
3. When set to the correct mode, the interior lights will operate from a door operated switch so if the switch has failed the lights will either stay on or not operate at all when you open and close the door. Eventually these door switches fail with repeated use and need to be replaced. (Consider how many times the small door switch has been operated since 1996).
Dec 25, 2012 | 1996 Jeep Grand Cherokee
How do you replace brake light in 1976 2l kombi?
Brake light switch is located at the brake pedal, disconect switch & bridge wires at plug, if brake lights on switch is faulty, You probably have a fuse for interior illumination.
Jun 26, 2012 | Volkswagen Cars & Trucks
Interior light stays on...light is hot..food directly beneath light is not cooling
HI. There is a door switch that controls the interior lights. This switch is also connected to the fan motor circuits. The actual door switches will be the lone culprits in your case. They are not functioning at this moment. This switch fault will effect the cooling process and cause an abnormally high temperature inside the unit, due to no Evap fan action and interior light heat.
Simply replace the door switches to correct the issue.
Sep 04, 2010 | Viking DDBB363 Bottom Freezer Refrigerator
No Interior lights.
I would check the headlight switch. I cant believe the dealer would keep replacing the relay without checking something else. Obviously something is blowing the relay. Short in the switch,or a bad wire.
Mar 09, 2010 | 2003 Oldsmobile Aurora
The inside light doesn't shut off
Open one door at a time and press the door button-switch (in the door-frame, hinge side usually) to see if that switch will shut off the light. If you find one that does, either extend the button length slightly with hot glue or epoxy, or replace the switch. Make sure the light has not been turned on at the light or that the switch is bad.
Nov 15, 2009 | 2004 Ford Crown Victoria
Interior lights
THE SWITCH IN THE OOVERHEAD CONSOLE (THE FIRST SWITCH TURNS THE INTERIOR LIGHTS OFF AND ON.IF THIS DOES NOT WORK TRY PULLING OUT THE PART AND UNPLUGGING THE SWITCH.MY SWITCH IS DEFECTIVE.HOPE THIS HELPS.
Dec 27, 2008 | 2004 Pontiac Montana
Interior lights
its your door penn switch which is in control of turning on the light, when u turn right, so start with the passenger door pin switch, then check all switches as well, replace one or all the malfunctioning swtich,wiggle or slightly touch the switch to see if the light is affected if it is replace the switch
Aug 01, 2008 | 1997 Honda Accord
Refrigerators Logo
102 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
