Question about Vacuums
My hoover shampooerworks good wih one problem. It doesnt throw waer when i press the sprayer
    New Friend:
  • 54 Answers
Will the pump spray work without the vacuum being on? If so Listen for the pump spray motor. If you can hear it whining then you may have something plugged like a hose or the hole at the end of the hose, also make sure the filter in the water reservoir is not plugged. Maybe the Impeller is bad in the pump motor.
If you don't hear the pump motor then you may have a bad motor or the button you push/pull could be bad or the wiring harness may be bad. Good luck
Posted on Nov 14, 2014
Hetty hoover not working
more than likely the motor has burnt up and they are not repairable , made as throw away units
Jan 05, 2018 | Hoover Vacuums
My Hoover shampooer picks up solutions,but will not spray out solutions. Help
The hose between your solutions tank and the sprayer is probably clogged. If you can hear the sprayer noise, and get no spray, you will have to get some solvent and use a syringe to clean the line. Remember each time you use it, you should pass two tanks of fresh water through it to clean it so it won't be clogged for your next use.
Jan 02, 2018 | Hoover Vacuums
Cleaner not spraying/spinsrub attachment
My hoover unit is older, but I had constant problems with the sprayer unit. I recommend returning the unit for a refund or getting an Return Authorization number. They may send you another unit and then you can see if the new one works. If the sprayer does not work, sometimes you have to take the handle apart to discover how it's put together.
Oct 16, 2013 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover spot scrubber sprayer not working well.
you can replace both tubes if it helps or you can check for blockages and check the pump off the video below
http://www.youtube.com/watch?feature=player_embedded&v=1sSVIu6arbY
Oct 31, 2012 | Tti Vacuums
My hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
May 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
My hond spin sprayer on my Hoover Legacy series
it is clogged. the hose part were it sprays is most likely to be clogged with debree. It happens all the time with hoovers
Sep 11, 2009 | Hoover Vacuums
My shampooer leaks
you need a new tank old tanks cracked at the seal hoover came out wih a replacenent tank old tank will have a crack in it by the seal
Nov 09, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
