Question about Refrigerators
How do i tighten the freezer bar that opens the freezer
  • Refrigerators Master
  • 15,557 Answers
If you are saying the handle on the door is loose, you have to remove the door liner to get to the bolts that hold it.
Posted on Nov 13, 2014
The chain has come off. I put it back but it is too loose. How do I tighten it
Should be a screw next to the bar. you can tighten it and it will tighten the chain. Keep in mind that the 2 bolts holding the bar and cover in place have to be loose to do this.
May 27, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Freezer door opens
This sounds like an alignment problem. Loosen the hinges slightly and place the door in the closed position and duck tape it in place. Tighten the hinges and check it for seal. Door is heavy by itself so empty it first and work with some help.
Apr 01, 2014 | Maytag MSD2732GR Side by Side Refrigerator
Chain tension
Pick up on chain and tighten until the teeth that run in bar groove are half way in the groove, to tighten loosen bar nuts on side of saw. There will be a screw either on bottom of saw on bar side or between bar and dawg( three or four pointed thing you see next to bar). Tighten screw as you turn the chain until when you pick up on chain it will raise the teeth that go in the bar groove to about half way. Do not over tighten or will burn up the bar, better a little loose than to tight. Don't forget to re-tighten bar nuts.
Feb 10, 2014 | Ryobi Garden
Alternator belt
Remember this rule;
lefty loosy, righty tighty!
You'll have to loosen the lower mount bolt as well as the slide bolt. Use a pry bar to tighten the belt until you have about 1/2 " to3/4 " play on the longest open section of the belt. Hold the pry bar as you tighten the slider bolt, then tighten the mount bolt.
Jan 25, 2014 | 2004 Chrysler PT Cruiser
Light blinks off and on when door is open
If you mean that the freezer cabinet light flashes check the lamp fitting and ensure the bulb is fully tightened, they have a habit of becoming loose with the expansion and contraction of the fitting/bulb as the freezer compartment cools with the door shut and the bulb warms when the door is open.
Jan 09, 2014 | LG LFD22860 Bottom Freezer French Door...
How do I tighten the screws on the freezer handle?
Its hard to tighten it to how it was earlier. The company tightens it first and then forms the outer layer of the handle. You can't tighten it yourself without piercing those handle bars. If you want it to be how it was before, contact the company. Else do it yourself.
Apr 22, 2010 | Viking VCBF036LSS Stainless Steel
Cannot tighten the chain bar
Make sure the bar is positioned on the bar adjusting pin before you tighten cover. Adjust tension with bar adjusting screw, then tighten bar bolts.
Mar 25, 2009 | Poulan PP4218AV 18" Chain Saw
After i use chainsaw the chain loosend
First you loosen 2 bar nuts , then tighten adjuster screw ,this is on cover behind bar nuts or between bar nuts or inside bar on crankcase depending on what model you have ,its also helpfull to lift nose of bar while you tighten adjuster,dont over tighten chain ,then tighten bar nuts
Nov 17, 2008 | Husqvarna Chain Saw 20" Bar
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Oct 15, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
