Question about Home
How do I replace the seal on a kohler one piece toilet k3434bb seal part # 83888
Toilet continues to leak for about 20 seconds than refills. Seal seems to be worn in the center hole where the flush valve fits parts: seal 83888, valve kit 83664, shut off works fine.
2 Suggested Answers
  • 82 Answers
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Posted on Dec 30, 2009
Aqua piston toilet keeps running....
Kohler customer service has provided a free seal (yellow) to replace the original seal (red)on the bottom of the Aqua Piston. The yellow seal is a big improvement over the red seal, but the toilet tank still leaks. I am ready to return the toilet to Home Depot.
Sep 20, 2013 | Kohler Cimarron Comfort Height elongated...
Refill valve
This happens when the seal on the flood tube is leaking and there is an imperceptible leak into the bowl.
Jul 13, 2012 | Kohler Home
Kohler santa rosa fills, shuts off, a little water leaks from tank, toilet refills and repeats the leakage into the drain.
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Dec 27, 2011 | Kohler - Toilet - One-piece - Santa Rosa -...
The water in the tank continues to leak out and the tank has to continue to refill. I have replaced the flapper, I have taken the tank off the toilet and check gasket alignment. The tank does not leak...
There are only a coulple of places that the toilet could leak or, overflow and give you this problem. When you replaced the flapper valve, did it have an extra piece of rugger on it? Universal flappers have a round piece on them that are designed to fit over the overflow tube. If you flapper had this piece and you don't have need for it, you need to cut that out, if the flapper "hooks" to the overflow assembly. Leaving that piec on can contort the shape of the flapper and make it so it won't seal. If you are noticing constant movement(slight swirl) in the bowl, make sure the back tank is not constantly overflowing into overflow tube. If this is the case, your water level is too high. You will either need to adjust the water level and/or replace the fill valve. If you can hear the toilet running or leaking, push down on the flapper, if it stops, you have a problem with the flapper and/or the chain adjustment. When you install the flapper, you have ton make sure the chain is long enough to let the flapper fall and seal but, not so long that it can tangle or get between the the flapper and it's seal below it.
Jun 19, 2011 | Jacuzzi Home
Trickle leak refill 1-2 minutes city water 40 PSI
the flapper valve is a common piece to obtain and easy enough to replace..
Aug 02, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Runs for 6 seconds every 35 min. flap replaced.
Trace the leak point with some food dye. If its the closer seal it usually a $5-6 fix at your big box hardware store like homedepot. If it is the closer take the old one with you for reference.
Mar 16, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Dec 28, 2009 | Kohler K-3489 Cimarron Comfort Height...
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Oct 28, 2008 | American Standard 2294.011.020 Afwall...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
