Question about Garden
Looing for parts 6.5 petrol briggs and stratton motor.
  • Garden Master
  • 17,167 Answers
There is a specific model number on the housing of the motor, can you post that.
Posted on Nov 13, 2014
  • 1129 Answers
SOURCE: Briggs and stratton engine surges and slows, repeatedly
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
Posted on Jul 25, 2009
mowerman1857
  • 389 Answers
SOURCE: how much oil to put in a 6.25 briggs and stratten
They hold APPROXIMATELY 20 ounces. Put in around 18 oz and start checking the dipstick and adding a little until it gets to the full or MAX or whatever it says on your particular engines stick. Each time you ad a little, give it a chance to drain down or you will get a false reading
Posted on Sep 20, 2009
  • 110 Answers
SOURCE: where can i get a manual for a briggs and stratton
You can download a manual for the engine from Briggs & Stratton's web site - you just need the numbers off the blower shroud. No manual exists for the actual mower.
Posted on Sep 22, 2009
  • 18 Answers
SOURCE: wanted briggs and stratton 92908 manual
Find the B&S website and you should be able to download a parts or service manual.
Think it is briggsandstratton.com.
You will also need your type number (after the 92908).
Posted on Apr 18, 2010
hunter19_46m
  • 7482 Answers
SOURCE: mountfield petrol mower HP470 problem with
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times or spraying starting fluid into the carburetor, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
Where is oil filter on 13.5 briggs
Briggs & Stratton Riding Lawn Mower Engine Oil Filter #696854 ...
? 2:05
https://www.youtube.com/watch?v=QjYmbfGU0qg
Aug 22, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the oil filter on a Briggs and Stratton small ...
Oil Change- Briggs & Stratton 12.5hp Mower - YouTube
? 5:05
https://www.youtube.com/watch?v=udjoD-mW5ig Aug 15, 2012 - Uploaded by Alex's Bikes and Motors
Oil Change- Briggs & Stratton 12.5hp Mower. Alex's Bikes and ... This is going to sound weird, but I can't ...
Oil Filter 492932S - Briggs & Stratton Parts
https://shop.briggsandstratton.com/us/en/parts-and.../oil-and-oil.../oil-filter-492932s Briggs & Stratton oil filters are engineered to keep your Intek, Vanguard OHV and twin cylinder engine running smooth. Save on costly repairs -- order genuine parts today!
oil filter on 13 5 briggs Google Search
Mar 12, 2018 | Briggs Garden
I have a sovereign 375, the cable which goes from the Handle to the engine has broken, is there another model/type of mower that will fit? Thank you
Contact this company https://www .briggs and stratton.com/ they sell all parts for beiggs and stratton. Give them the model # of the mower and they will be able to sell you the right cable
Sep 23, 2015 | Briggs & Stratton Garden
98902-2065-B1 briggs & stratton oil:petrol ratio pls
This is a 4 stroke engine which requires an sae 30 weight oil in the crankcase and straight gasoline (petrol) in the fuel tank
Jan 19, 2013 | Briggs & Stratton Garden
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 | Garden
My flymo briggs & stratton quick silver 46d
Your carb needs to be taken apart and cleaned
Jun 19, 2010 | Briggs & Stratton Garden
Remove starter motor briggs and stratton lawn tractor
My briggs 16.5 moptor wont turn over. It comes up on compression and stops. I have tried to jump it but the cables get really hot. Is my problem in the starter motor?
May 30, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
