Question about Plumbing
Why is my Danze, Single leaver, pull out faucet, (D456513SS), leaking from the small hole in the rear of the base?
    Master:
  • 560 Answers
Worn "O" rings in the faucet body.
Posted on Dec 28, 2014
5 Suggested Answers
  • 3 Answers
SOURCE: don't know what side allen key to use on danze
Buy a cobination set of allen keys usually between 1mm to 10mm and use the one that fits
Posted on Jun 17, 2009
  • 297 Answers
SOURCE: No water to single hole faucet after installation
the cartridge has trash in it.remove and clean,will work after that is done.
Posted on Jul 15, 2009
  • 14532 Answers
SOURCE: The pullout faucet wobbles when returned to the base.
check that nothing blocking hose return weight under sink
Posted on Oct 06, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: faucet is leaking from the cold water line inside
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Posted on Mar 30, 2010
Leaking pull out spout
Usually, it is caused by a worn out o-ring.
Jan 31, 2014 | Danze D403412 Melrose Single Handle...
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
Water leaking around base
Make sure aerator is tight and check cartridge under the handle
Oct 29, 2009 | Danze & Antioch™ Single Handle...
Oct 06, 2009 | Danze D405058 Parma Single Handle...
Leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Sep 25, 2009 | Danze D403412 Melrose Single Handle...
Don't know what side allen key to use on danze D456513SS to fix a leak?
Jun 17, 2009 | Danze D403412 Melrose Single Handle...
May 24, 2009 | Danze D222158 Parma Single Handle Hole...
Leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
Dec 30, 2008 | Danze D403412 Melrose Single Handle...
Plumbing Logo
54 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
