Truck loses oil pressure when idling
You need to drop the oil pan and check the pick up tube and screen and O-rings. While you are in the process, check the crank shaft for signs of bad bearings. There is a TSB out on this issue and the most likely cause is the o ring on the pick up tube. When you put the pan back on, you need to use a new gasket and make sure that the surfaces are clean. ATV is not a recommendation and also be sure to not over tighten the pan bolts.
