Question about Cranium Cadoo Board Game
Need replacement clay for game
Can I buy replacement clay on line.
My terracotta clay becomes hard in the bag how can I make it usefull
Wrap in a wet towel for a few days,
Should come good!
Jul 09, 2017 | Cars & Trucks
Building my house
What game are you asking about? If you mean Minecraft, clay can be found in water. I find most in water around sand.
Apr 23, 2014 | Video Game Consoles & Games
Where buy replacement for clamp and nut
They are available on eBay or you can buy one of the cheap clay rolling machines and they have the same clamp and handle. You can keep an eye out at Goodwill's as I see them all the time. Good Luck!
Apr 02, 2014 | Atlas Translator Marcato Atlas 150 Handle...
Concrete tile or Clay tile
clay tiles have little more lifespan than that of concrete. While clay tile is only popular in its red color, concrete tiles are available in wide range of colors.
Clay tiles break easily but concretes do not. But both concrete and clay tiles are the pinnacles of beauty.
Dec 09, 2013 | Washing Machines
Are there different cooking tajines and serving ones? can i get either one to cook in?
The Cooking Tagine
Cooking tagines may look the same as a serving tagine so it is important to purchase your tagine from a reliable source. If you are buying online make sure the description states that the tagine was designed for cooking. Cookable clay tagines are made from a different clay body that is a refractory clay (clay with a melting point above 1600C); designed to take the heat of cooking without shattering. While many of the cooking tagines tend to be simple solid colors and overall less decorative that is not always the case.
Some cooking tagines have "steam release" holes in the lid. Hand made, rather than manufactured tagines may not have a steam hole because the lid does not fit tight to the base and steam can release during the cooking process. Manufactured tagines are more apt to have tight fitting lids and require the steam hole.
The handmade cooking tagines, as well as any earthenware ceramics will craze with use. Crazing gives the surface a "crackled" appearance but does not affect the functionality.
-found on the website http://www.gourmetsleuth.com/Articles/How-To-Select-Cooking-Tools-647/tagine.aspx
Apr 10, 2013 | Home
Basement has clay tile foundation, it's scaling, what can I do to stop it?
you will need to replace this tile with something else.
Dec 19, 2011 | Plumbing
Sculpey and firm sculpey tend to crumble even after kneeding
Found this on the Sculpey website- Hope it helps :)
"If your clay is just a little dry or firm, it may only require the addition of Sculpey Clay Softener to reconstitute it (about 6 - 8 drops per 4 oz clay or 2 - 4 drops per 2 oz clay).The Clay Softener will not restore clay once it has become very hard or after it has been baked. If the clay is already crumbly, it has either had too much exposure to heat or old enough to have already undergone some chemical changes. At this stage, it cannot be reconstituted satisfactorily. Adding a pinch of Sculpey MoldMaker to clay that is a little dry or firm will also help reconstitute it."
http://www.sculpey.com/faq-new/209#
Sep 21, 2011 | Sculpey Crafts & Hobbies
The 3/4" main water line has a leak and needs to
Hi. I seriously doubt that you can avoid digging a new trench.
Aug 01, 2011 | Plumbing
I have some roseart modeling clay and I don't have the box it came in. Can it be dried in the oven and if so how do you do it?
You can dry it in the oven:
1. Preheat the oven to 300 degrees F. Remove all pots and pans from the oven. The clay gives off smoke that adheres to the pots and pans.
2. Place the modeling clay on a baking sheet and set it in the oven. Place it on the bottom shelf of the oven to give more room overhead. To prevent the clay from sticking to the baking sheet, place parchment paper on top of the baking sheet. Once you are finished, it is safe to use the baking sheet for cooking again, just wash it off with warm water and dish soap.
3. Wait at least 20 minutes and check on the clay. Touch the Rose Art clay to see if it is still soft. Larger, thicker clay pieces take longer to bake, so if the clay is still soft place it back in the oven
4. Check the clay every 10 minutes until the entire piece is hard. Once hard, remove it from the oven and allow it time to cool.
Hope it helps out!
May 08, 2011 | Roseart Toys
Cranium Cadoo Board Game Logo
100 people viewed this question
Top Cranium Toys Experts
ray gallant
Are you a Cranium Toy Expert? Answer questions, earn points and help others
